  • 51
  • 6
jalzoo
Graphing SH3 Power levels with cacti?
Is it possible to graph SH3 Power levels with cacti on home server?.
I have no idea were to start with it i'm not even sure if it is possible with the SH3 just wondered if any one else has managed to get it running.
  • 1.34K
  • 102
  • 246
stevedh2
Knows their stuff
Re: Graphing SH3 Power levels with cacti?
Maybe,
1st step though is to get the data from the SH3 using a command line.
as far as I can tell there is no telenet or ssh access, which is what I've used with my other modem.
The alternative is to access the web page, but I can't find a direct url that will give you access to the relevant pages. If you can find a direct url that will do that, then its just a matter of parsing the raw web page data returned and using that.
  • 1.34K
  • 102
  • 246
stevedh2
Knows their stuff
Just thought I'd update this incase anyone in the future wants to do this.
You can get the downstream
power levels x 10 from http://192.168.100.1/walk?oids=1.3.6.1.2.1.10.127.1.1.1.1.6
SNR x 10 from http://192.168.100.1/walk?oids=1.3.6.1.2.1.10.127.1.1.4.1.5
upstream can't seem to find the power levels, but
http://192.168.100.1/walk?oids=1.3.6.1.2.1.10.127.1.1.2.1
will give you a load of upstream values
ps. I'm using mine in modem mode, so you'll probably need to change 192.168.100.1 to 192.168.0.1 if you aren't
I haven't yet got around to parsing the output to use for graphing, but will do as soon as I have some spare time.
