leso1
Message 1 of 9
Fibre Broadband Installation
Hi, a friend is having fibre broadband installed in the road by a company called Gigaclear and has been told by them they will be their only provider. Is that correct
Helpful Answers
  • 16.29K
  • 1.36K
  • 3.31K
Message 2 of 9
Re: Fibre Broadband Installation
doubt it, looks like they install FTTP (fibre to the premises) compared to virignmedias common FTTC (fibre to the cabinet), looking at the site can get rather costly depend on distance from cabinet.. since there are small fibre companies similar to how virginmedia operate.
  • 546
  • 42
  • 84
DavidJWalker
Rising star
Message 3 of 9
if i am right Gigaclear runs on openreach network but i am not 100% on that
Using VIVID 350 Optical Fibre, Player TV, Talk Weekends
Just another VM user trying to help out so my answers may be wrong.
If you do like my answer please mark it as helpful; it may help others
  • 16.29K
  • 1.36K
  • 3.31K
Message 4 of 9
from what i've read about them they install their own cabling no piggy backing onto BT openreach network.. maye on their head end might use their core (not read that far into it) and don't plan to
  • 1.24K
  • 93
  • 231
stevedh2
Knows their stuff
Message 5 of 9
In reply to the OPs question, Gigaclear's connection is much like Virgins, in that they will be the only provider over their own network which is separate to BTs
You could also have an openreach connection via bt's socket, but this would note make use of anything installed by Gigaclear. You can get pretty fast speeds via Gigaclear though..
  • 85
  • 6
planetf1
Dialled in
Message 6 of 9
The gigaclear web site has a fair bit of info...
For a price you can get a 1000 Mbps upload - the best virgin can do is 20... that's quite a difference. But their footprint is very small
  • 16.29K
  • 1.36K
  • 3.31K
Message 7 of 9
yeah but the cost of getting the cable laid is the biggy can run into hundreds easily
All Replies
  • 16.29K
  • 1.36K
  • 3.31K
Message 2 of 9
  • 546
  • 42
  • 84
DavidJWalker
Rising star
Message 3 of 9
  • 16.29K
  • 1.36K
  • 3.31K
Message 4 of 9
  • 1.24K
  • 93
  • 231
stevedh2
Knows their stuff
Message 5 of 9
  • 85
  • 6
planetf1
Dialled in
Message 6 of 9
  • 16.29K
  • 1.36K
  • 3.31K
Message 7 of 9
  • 546
  • 42
  • 84
DavidJWalker
Rising star
Message 8 of 9
i say it depends on if the area you in have gigaclear cover they only have a few areas
  • 9.37K
  • 362
  • 2.31K
Message 9 of 9
Their only FTTP provider probably. If you can get Gigaclear then definitely go for that! Going to be miles better than a Virgin cable or BT openreach FTTC line.
If you want to know what broadband services are available punch the postcode into this site: https://availability.samknows.com/broadband/exchange_search
Then click on the exchange that comes up.
