johnm9338
External cable box
How do I report a damaged external cable box on my property? The box is broken and the cables are exposed. Online suggests to call, however, none of the selection options on the phone appear to cover this.
  • 14
Stu40
Re: External cable box
I had the same problem a couple of months ago after builders where next door.
I used the  tv fault section and reported the fault explain water not good for cables engineer came out and fixed
johnm9338
Thanks Stu
