TV
Ask a question
Making Waves
craigparn
replacement remote
My remote control has stopped working,nothing in the way,new battery's and the like. How do I get a replacement?
Please use plain text.
Usually Always Right
dozer167
Re: replacement remote
Hi craigparn,
                    you can either wait for a Virgin tech to answer your post, or you may call 150 FREE from a VM landline or alternatively call 08454541111 from any phone or mobile, to arrange to have a FREE replacement remote ordered & sent out to you.
Hope the info helps.                   Regards dozer167
I do not work for Virgin Media, I'm just another customer. If someone's helped you out say thanks by clicking on the kudos star. If someone's solved your problem, why not mark their message as a Helpful Answer?
Boffin
LesleyChenard
Hi craigparn,
I've ordered a remote for you, which should arrive within 7-10 days via normal 1st class post.
Regards,
Lesley Chenard
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
Moderator
LisaS235
Fresh as a Daisy
Ju1974
replacement remote
Remote is broken need a replacement. Thanks
Fresh as a Daisy
granty89
Hi there
I was wondering if you could help, my mums Virgin media remote had died a death after so many years, how might I go about ordering a new one please?  Any help would be much appreciated.
Wizard
Dale_H
Hi Ju1974
In order to help you further could you please PM me your details such as house number and postcode.
Cheers
Dale Heaven
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
Got a problem? Check for faults online with our service status and fault checker.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Wizard
Dale_H
Hi granty89
Please could you provide the details for the account in question via PM such as postcode and house number
Dale Heaven
Fresh as a Daisy
KOMP
Hello
did a little google of the internet and my search has brought me here
i am also in need of a replacement remote for my virgin media box.
if this request can be handled here i would be most grateful.
many thanks
regards
kieren
Fresh as a Daisy
pagriffin
Hi there,
I also have a remote on which the buttons on the right hand side on the numeric keypad part have all ceased to work. Have tried new batteries, and the buttons on the box itself all operate correctly.
Would be graetful if someone could advise how best to order a replacement.
Many thanks
Paul G
