Fresh as a Daisy
sammidge
my remote control has stopped working!
my remote control has stopped working, after changing the batteries it still isnt working!
Please use plain text.
Usually Always Right
Mark_B
Re: my remote control has stopped working!
Hi, can you use the buttons on the front of the box or are they not responding as well?
Mark Brooks
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
Fresh as a Daisy
sammidge
yes they are working, but it is very difficult to use the box this way. Could i be sent a new remote control please.
Fresh as a Daisy
sammidge
It is a V+ box, that I have, thankyou.
Mark_B
No problem, I have ordered a new one for you, please allow 7-10 working days for delivery.
Mark Brooks
