TV
Ask a question
Making Waves
d_a_barker
Virgin Media box won't turn on
The Virgin Media box in our house last night went from having the usual blue lights to just a single red light. Neither the button on the front of the box or the remote will turn the box on. Is the box completely broken?
Please use plain text.
AMWSmith
Re: Virgin Media box won't turn on
Try disconnection it from the mains for 5 mins and see if it springs to life once plugged back in.
Also what Box do you have?
Tony.
2X TiVo 500G (TV XL) 152Mb BB & Weekend Calls.
Making Waves
d_a_barker
Hi, it's a Virgin VBox HD, the model number is 4585DVB. The box has been switched off and on again and we're still having the same problem.
AMWSmith
Suspect a dead box. (Supprised as the cisco VHD boxes normally are pritty stable)
You can wait for a forum team to pick up the post (can take upto 7 days) or call in to CS via 150 from a vm line or 0845 454 1111 (Mobiles charge more then local rate for 0845)
Tony.
Making Waves
d_a_barker
I already tried to call them but it said office hours ended at 5:30pm. I'll try them again tomorrow morning, thanks for your help.
Mythical
jb66
Common fault with a VHd, needs swapped
Boffin
LesleyChenard
Hi d_a_barker,
I have booked a technician for you as your stb is not online. Could you please just check that all cables are securely connected to the box, tv & socket in the wall. I have sent you a PM with the details. Should you wish to either cancel or reschedule the appointment please visit My Virgin Media, Service Status. Just for future reference, you can also use this service to diagnose faults & if necessary book an appointment.
Regards,
Lesley Chenard
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
Making Waves
d_a_barker
The cables are all secure, I've checked them all and it still doesn't work. Thanks for arranging a time with the technician.
Fresh as a Daisy
stewartchinn
Our Virgin box has the same problem and I've tried all the steps on the site.
Proof’s in the Pudding
Emily_L
Hi stewartchinn,
I have checked the box from here aswell and its showing offline, so we will need to book an engineer to attend your property. If you could send me a private message with your house number and postcode and I will check the appointment times for you.
Emily Lewis
