TV
Searching for something?
Emerging Talent
tboman
Virgin Media box stuck on AP52 message code
My standard Virgin Media (non V+) is stuck on the AP52 error which I have read means the box is dead. Is this a correct diagnosis and if yes, will I need an engineer out?
Regards,
Tony
Please use plain text.
Human Answer Bank
Michael_S
Re: Virgin Media box stuck on AP52 message code
Hi Tony,
AP52 is usually a failure with the cable input (white cable that screws into the back on the box).
If that is in and secure then it will require an engineer to visit.
Can you check and let me know.
Kind Regards
Michael S
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Emerging Talent
tboman
Hi Mike,
I turned the box off, tightened the coax at both box end and wall plate end. I then turned it on again. It sat on NIT for 15 minutes or so, then went to AP52 again. It is still stuck there.
Regards,
Tony
Emerging Talent
stevenl
Don#t know where you live Mike but it's like this in Dundee also
Fresh as a Daisy
markmcq
this is also the case in carnoustie 11 miles ousige dundee
Fresh as a Daisy
markmcq
hope everyone  else has same. my tv has gone back to normal by itself
L33t h4x0r
Laura_S
Hi tboman,
I'm having trouble locating your account.
Can you please select  my name and send me a Private Message with your house number and postcode so I can locate your account.
Laura_S
Got a problem? Check for faults online with our new service status and fault checker
L33t h4x0r
Laura_S
Hi markmcq,
Thanks for confirming your service has returned, glad it's OK now.
Laura_S
L33t h4x0r
Laura_S
Hi stevel,
I've checked and there are currently no area faults affecting you.
Can you please confirm if you still have a fault.
Laura_S
Emerging Talent
tboman
Hi Laura,
I have PM'd you my address details,
Tony (tboman)
