TV
Ask a question
Clever-clogs
flavionf
Virgin Box Coaxial Cable
[ Edited ]
I have two coaxial ports on my little white isolator box, i wonder if i could have a long cable so i can connect it to my virgin box which is in another room, at least 6 metres long. I have a splitter but when i use the splitter to connect it to my virgin box and my broadband modem, problems occur where the broadband stops working. So is it possible if i could use the other port on the white box to connect to my virgin media tv box, and if it's possible can i have at least a 6 metre long cable to connect the virgin box to the isolator box? Thank you.
Please use plain text.
