TV
Ask a question
Emerging Talent
fisherman66
V+HD Box Stand By Mode..
Can the V+HD box be powered down other than un plugging? I presume that when the red light is showing that the box is just in stand by and not powered down?
Please use plain text.
Mythical
jb66
Re: V+HD Box Stand By Mode..
No it can't
No longer registered
Font of All Knowledge
Peter_
If it is a Samsung V+ the is a power button on the right hand side at the back of the machine but if switched off it will not record any set programmes which is the reason for leaving the box in standby.
_______________________________________________________________
Has this post helped you out? say thanks by clicking on the RED STAR +☆
If I helped to answer your question then please click 'Helpful Answer' also
Emerging Talent
fisherman66
Thank you Peter...
nodrogd
The V+ now has a power save mode issued with the latest update, which turns off the clock display etc when the box is in standby.
To change the setting go to Home>Settings>Clock Settings.
Cable customer since 1993. Services: XL TV, Sky Sports & Movies (2xV+), XL Telco, 100Mb BB, Virgin PAYG Mobile
