TV
Searching for something?
Emerging Talent
zzz999zzz
TiVo box making loud hum
I had a TiVo box installed last week, which I'm really enjoying so far.  There is one problem with it though...
It has been making a loud hum/ buzz since installation which I don't think can be right.  I've looked elsewhere and people have described it as "silent", also the other boxes I've had from Virgin Media (V+ and VHD) have both been silent.  I can hear the noise above the TV, so not what could be described as "silent"!
Has anyone else experienced this?  There are no notes about it anywhere, or instruction on the kind of space it needs (i.e. area required for it to not over-heat).  It does have a small DVD player resting on it, but is in the same situation my V+ was, which I never had any problems with.
Anyone got any ideas of how I can solve this irritating problem without having to get an engineer out?
Tom
Please use plain text.
Expert Opinionator
Champs
Re: TiVo box making loud hum
nothing should be sitting on top of it as you can quite clearly see the vents are on top. Also you could try making some little polystryrene feet to put under it as my v+ use to hum when it was in a wooden cabinet and use to hum until I did this.
______________________________________________________________
**I am employed by Virgin Media**
**Everything I post is in my own time and my own opinion**
L33t h4x0r
Laura_S
Hi zzz999zzz,
As Champs has correctly advised nothing should be resting on top of the TiVo box because it will cause the box to overheat by blocking the vents.
Can you please remove the DVD player allow the TiVo box to cool and let us know if the box is still making a noise?
Laura_S
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Got a problem? Check for faults online with our new service status and fault checker
The Sorter
chops
The Samsung V+ box has a good design feature using rubber feet that allow a very slight movement and isolate the box from vibration noise passing through to the surface it's placed on.
If the Tivo doesn't have anything similar try placing it on a thin rubber mat such as that sold as anti-slip - matting for car boots etc.
Proof’s in the Pudding
gravy1
a slight hum is normal but it maybe the location of the box causing the sound to be amplified so I agree with above posts... give it space so the cooling fan can slow down and place it on a rubber matt or some rubber pads.
Emerging Talent
zzz999zzz
Thanks everyone for your advice.
I've had a play and agree it is definitely caused by the box vibrating.  I will test out some different feet and let you know how I get on...  my first try of a couple of books hasn't worked!
Thanks again,
Tom
Emerging Talent
zzz999zzz
Hi all,
Update on this.  After trying various different DIY feet and speaking to different people I got the box swapped.
No difference I'm afraid.  What I don't understand is why the box continues to vibrate when it is switched off.  Only unplugging the power cord makes it stop.
Also, my understanding is that there is no fan inside the box, so that shouldn't be an issue.
If anyone has recommendations for suitable rubber mats that would be much appreciated.  If that doesn't work I'm going to have to go back to V+.
Thanks again for your advice so far,
Tom
Specialist
jonandmarkuk
I noticed a hum from the Tivo when I first had it, but now I hardly seem to notice it.
The reason it hums unless the power is unplugged is because it's 'always on' even in standby as it records a buffer of the TV station it's on.
The idea being that if you walk in half way though a program that's on you should be able to have enough buffer to rewind to the beginning.
The Sorter
chops
zzz999zzz wrote:
Hi all,
Tom
It can only be the hard drive inside that is whirring away continuously making the hum as the psu is a separate brick - they sometimes hum a bit also.
Try a rubber mat from a car accessory shop (Halfords ?) and cut it to size.
Spoils the aesthetics though from VM's design team if all TiVo's end up with an old car mat underneath !!
Or try resting it on a thick telephone directory / yellow pages...........
Emerging Talent
zzz999zzz
It's resting on feet made out of a chopped up mouse mat and cork table mat at the moment, so a car mat would probably be an improvement!
Thanks.
