TV
Searching for something?
Making Waves
MG46
Replacement remote control
I need a new remote control. I've change the batteries many times but it makes no difference.
Thanks!
Please use plain text.
L33t h4x0r
Laura_S
Re: Replacement remote control
Hi MG46,
Can you please confirm if all the buttons have stopped working or just certain buttons. Also can you please confirm if the receiver light flashes on the box when you press any buttons?
Laura_S
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Got a problem? Check for faults online with our new service status and fault checker
Making Waves
MG46
Hi Laura
Some of the buttons work but you have to press extremely hard to get the light to flash on the remote control and then the reciever light flashes. It's been like that for quite some time but it's now almost impossible to use.
Mark
Human Answer Bank
Ray_P
Hi Mark,
Please send me a private message with your address and postcode and I'll send a replacement.
Kind Regards
Ray_P
Making Waves
MG46
Thank you for sending me a new remote so quickly – much appreciated!
Mark
Making Waves
Snuffyarroder
My remote control stopped working tonight. Have replaced batteries and checked there are no obstacles or sticky buttons but still dead. Please could you send a replacement?
Thank you
Boffin
James_B
Hi Snuffyarroder
I'm sorry that your having problems with the remote control. Can you confirm is the led on the remote control or set top box coming on when you press a button on the remote? Also, does the set top box respond to the buttons (ch+ ch-) buttons on the front?
James
James Budden
Seen a useful post?Problem Solved?Fault with your service?
Making Waves
Snuffyarroder
Hi James
No LED on either remote or box comimg on when remote pressed. Channel +/- working on box.
Boffin
James_B
Hi Snuffyarroder
I have ordered you a replacement remote control, please allow between 7 and 10 days for it to arrive.
James Budden
Making Waves
Snuffyarroder
Thank you James. Kind regards
