TV
Searching for something?
Fresh as a Daisy
WIsaac
Remote Red Light Stays on
The red light won't go out on the remote and i have replaced the batteries.
Do i need a new one?
Please use plain text.
Proof’s in the Pudding
Emily_L
Re: Remote Red Light Stays on
Hi Wlsaac,
Are you able to change channels on the front of the box ok?
Emily Lewis
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
Fresh as a Daisy
WIsaac
I am, yes.
Emily_L
Hi Wisaac,
We will need to order you a new remote control.
However, I cant seem to locate your details. Could you please send me a private message with your house number and postcode and I will order one for you.
Emily Lewis
