TV
Ask a question
Fresh as a Daisy
Luzcol
Red lights stays on remote
Hi, the red light on my remote is staying on and the remote won't work.
I have changed batteries and checked all buttons aren't sticking.
What else can I do?
Please use plain text.
Wizard
bdbasdjrcfbmlb
Re: Red lights stays on remote
I might be wrong but it looks like your remote is packed out.... time to get new one...
Kath_F
Hi Luzcol,
It does seem that you will need to have a new remote control. If you give the faults team a call, they will be able to get one sent out for you within 3-5 days :smileyhappy: You can reach them on 151 (free) from a Virgin Media land line or alternatively 0845 454 1111 (chargeable) from any other line.
Kath
Help & Support Forum Team
Problem Solved?Fault with your service?We did warn you!
