TV
Ask a question
Fresh as a Daisy
paul_carter
Old Telewest Broadband Box
My box has started to freeze and not work correctly, the picture is terrible
will virgin charge to have it changed to a new model?
Please use plain text.
Gandalf
Claire_D
Re: Old Telewest Broadband Box
No we wont charge for a repair.  If we need to change the box we will do this free of charge.  Would you like me to book an engineer for you ?
Claire
Claire D
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Fresh as a Daisy
paul_carter
Should i ring 150?
Gandalf
Claire_D
Hi there
I can book you one now if you would like, or you can call 151 for the faults team.
Claire
Claire D
