Just joined
StuartAB
Cisco HD won't wake up
Just upgrading to HD with the Cisco box. During installation, lost power half way through and now box won't go off standby with either panel button or remote. No signal over HDMI or SCART to TV. Anyone know how to reset the box, please? Thanks, StuartAB.
Please use plain text.
Robert_W
Re: Cisco HD won't wake up
Hi StuartAB,
Sorry for your problem, you should have received documentation with a number to call the QuickStart team, they would be able to check everything and if need be book a technician.
The account still shows the old equipment.
Cheers
Robert Ward
Help & Support Forum Team
Got a problem? Check for faults online with our new service status and fault checker
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
