Searching for something?
Fresh as a Daisy
Mykeff
Wireless connection
Do I have to use an Ethernet cable for Tv anywhere? I already connect wirelessly from my TiVo to the super hub so why can't this be used for the connection?
All the guides seem to have only cable or home plug as an option.
Please use plain text.
Clever-clogs
griffly16
Re: Wireless connection
[ Edited ]
Hi - TV streams wirelessly for me to my laptop without any issues.
Once your device is registered then you can watch live TV according to your package - I get SkySports streamed without issues. Your Tivo box doesn't need to be connected by ethernet for this.
Captain Clued-Up
paultrademark
How do you have that set up?
_____________________________________________________________________________
1TB TiVo, 500GB TiVo, V+,
XL TV, 120MB BB, M Phone
If you like my post or want to thank me, click on the Kudos Star or Mark my answer as helpful
Expert Opinionator
mike_gain
Probably a wireless access point i.e. plug an ethernet cable from TiVO into access point. Access point talks to router, router and rest of network sees TiVo. There are loads on the market and you shouldn't need to spend more than £50 to get a good one,
BenMcr
If you already have TiVo talking to your SuperHub you don't have to change anything, however TiVo to TiVo streaming may not always work
Captain Clued-Up
paultrademark
Yeah I have similar but it was they way he worded it wirelessly from the TiVo.. when it's from an access point :smileyhappy:
