hatyak
yet again slow connection
First time poster here, but not first time having speed and/or connections issues with virgin.
Last few days we are having very slow speeds 1-2mbps (<300kbps!!), tried 2g and 5g wifi connection, changing wifi channels as well as tried connection with ethernet cable.
here are the up/downstream/network logs from super hub:
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)171000000179000000187000000195000000N/A211000000N/A227000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedUnlockedLockedUnlockedLocked
Channel ID1234N/A6N/A8
Modulation256QAM256QAM256QAM256QAMUnknown256QAMUnknown256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.952000N/A6.952000N/A6.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
N/AI=12
J=17
N/AI=12
J=17
Power Level (dBmV)-5.44-5.42-5.56-5.83N/A-6.17N/A-6.17
RxMER (dB)36.8436.8436.8436.84N/A36.84N/A25.47
Pre RS Errors315734711882540237437028N/A92405N/A-741306728
Post RS Errors273947119421004810739N/A10584N/A-1489730813
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID39N/AN/A37
Frequency (Hz)23600000N/AN/A36800000
Ranging StatusSuccessOtherOtherSuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)50.00N/AN/A50.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts000
0
First TimeLast TimePriorityError NumberDescription
16/03/2017 22:48:18 GMT16/03/2017 22:48:18 GMTWarning (5)84020200Lost MDD Timeout
Any ideas what to do, i am getting tired of virgin and the connection issues I experience with them.
Thanks in advance
  • 8.32K
  • 358
  • 586
Re: yet again slow connection
Hi hatyak,
Welcome to the Community!
Really sorry to hear you're having trouble with your connection.
I've run diagnostics on your equipment and I can see an issue with your Downstream Power levels that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
