mura86
Message 1 of 5
very slow speed
Hello, every day after 6pm to 12pm my connection is very slow i use wired Ethernet connection and this is the speed at the moment, do something to solve the problem because it is impossible to open a page
  • 9.34K
  • 797
  • 1.96K
Message 2 of 5
Re: very slow speed
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting. I would obscure  your Wan IP address.
Are you getting the poor speeds all the time or only during the evening?
mura86
Message 3 of 5
Re: very slow speed
i go slow only 6pm to 12pm in the rest of the day the connection is good
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
298750000 3.5 37.6256  qam 65
2 322750000 3.7 38.6256  qam 68
3 314750000 3.7 37.6256  qam 67
4 306750000 3.7 37.6256  qam 66
5 290750000 3.7 38.6 256 qam 136
6 282750000 3.7 38.6 256 qam 135
7 274750000 3.9 38.6 256 qam 134
8 266750000 3.9 38.6 256 qam 133
Channel ID Frequency(Hz) Mode Power
4 25800000 ATDMA44 64 qam 6400000 5120
1 46200000 ATDMA44 64 qam 6400000 5120
3 32600000 ATDMA44 64 qam 6400000 5120
2017-01-07 13:35:33.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:40.0082000700Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:40.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-09 16:04:37.0073025103Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-09 16:04:37.0073027100T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-09 16:04:37.0073000200REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-10 10:56:51.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-14 00:28:37.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-14 18:20:14.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-14 21:49:38.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-14 23:04:58.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-15 01:23:08.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-15 04:56:44.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-15 04:56:44.0068010600DHCP Renew - lease parameters tftp file-Va8201799de4e3b26.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-17 00:57:04.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-18 14:51:44.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-19 01:17:28.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-19 02:01:59.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-19 13:12:17.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-19 13:12:17.0068010600DHCP Renew - lease parameters tftp file-Va8201799de4e3b26.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mura86
Message 4 of 5
Re: very slow speed
ok now the speed is very slow 2.77 download
5986329906
  • 10.58K
  • 311
  • 653
Message 5 of 5
Re: very slow speed
Hello mura86,
Welcome to the community Smiley Very Happy
Really sorry to see you're currently experiencing slow speeds, I know this can be really irritating.
Checking your connection I can see that we're in the process of working on a fault in your area. The fault ref is: F004110347 and it's due for review on the 29th March, while this is present, you might see a reduction in your speeds, especially during peak time hours.
I know this isn't the best news, please accept my apologies and let me know if there's anything else we can help with.
Take care.
Heather_J
