  • 101
  • 10
francisuk1989
Dialled in
Message 1 of 8
utilization going on issue in the finc17 area
Since June have been posting about my speed issues, When i last had a engineer out he said there a utilization issues but only peaked at 8% what isn't enough to report however the last 2 days it has been so slower then before but only between 7pm-11pm (weekdays) and 9pm-11pm mostly weekend is worse!!, Yes i know is not much of a time slot but between 7pm-11pm is the most where i use my broadband and is gone to a point where my downloads are going from 2Mb then jumps to 7Mb back to 5Mb sometime the odd 20Mb but then drops in speed. The speed issues is affecting both PC and Xbox One, When im gaming at these hours of 7pm-11pm is gone to point where im lagging into games, Racing and FPS are mainly i try and avoid theses hours but why should i? I should beadle to enjoy gaming and any game in my spare time (when not working) Smiley Happy
This was still a going issue before i got given a Hub 3, So the Hub 3 isn't an issue, also my device are all wired, Xbox One, PC, I have checked all my device to see if anything is download but nothing is flashing at the back of the hub (a few flickers on PC LAN but nothing that's constantly flashing away)
About 9:45pm i downloaded a Stream game (PC) 04/10/2016 but this was very slow downloading between 4mb-11mb sometime 15mb but drops down in speed, I tryed selecting diff rent servers but i was still facing the same issues, Also checked again if anything was flashing at the back the Hub 3 but only the PC lan was flashing away.
12:13am everything seem back to normal, Is just a case of hours between 7pm-11pm, Will give another traceroute when i noticed speeds dropping.
C:\Users\HP>tracert gameclipscontent-d2016.xboxlive.com
Tracing route to e2835.dspg.akamaiedge.net [23.209.208.130]
over a maximum of 30 hops:
1 3 ms 5 ms 1 ms 192.168.0.1
2 * * * Request timed out.
3 15 ms 18 ms 27 ms brnt-core-2a-xe-031-0.network.virginmedia.net [80.2.137.105]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 28 ms 22 ms 27 ms nrth-bb-1c-ae0-0.network.virginmedia.net [62.254.42.134]
9 27 ms 30 ms 19 ms tcl3-ic-3-ae0-0.network.virginmedia.net [62.255.64.238]
10 22 ms 29 ms 36 ms m386-mp2.cvx3-a.ltn.dial.ntli.net [213.104.85.130]
11 25 ms 38 ms 22 ms a23-209-208-130.deploy.static.akamaitechnologies.com [23.209.208.130]
C:\Users\HP>tracert download.xbox.com
Tracing route to a948.dspd.akamai.net [62.252.60.193]
1 2 ms 2 ms 4 ms 192.168.0.1
3 17 ms 27 ms 21 ms brnt-core-2a-xe-031-0.network.virginmedia.net [80.2.137.105]
7 12 ms 14 ms 27 ms popl-icdn-1-ae0-0.network.virginmedia.net [62.254.84.158]
8 14 ms 11 ms 14 ms cpc3-stme1-3-0-cust193.cdif.cable.ntl.com [62.252.60.193]
VIVID 100, Hub 3.0
  • 10.82K
  • 308
  • 631
Message 2 of 8
Re: utilization going on issue in the finc17 area
Afternoon francisuk1989
Thanks for posting on the community. It's nice to have you here.
Sorry to read that you are experiencing issues with your broadband connection.
I've checked the network and the traffic is running low with no issues.
Have you noticed this issue since you last posted? If so are you able to post some speed test results whilst the Hub 3.0 is in modem mode please?
Hope to hear from you soon
Sam
  • 101
  • 10
francisuk1989
Dialled in
Message 3 of 8
with Router Mode, Computer is on LAN and taken about 9:32pm
C:\Users\Francis>tracert download.xbox.com
Tracing route to msxb.vo.llnwd.net [178.79.211.254]
1 3 ms 4 ms 4 ms 192.168.0.1
3 130 ms 186 ms 162 ms brnt-core-2a-xe-031-0.network.virginmedia.net [80.2.137.105]
6 106 ms 129 ms 165 ms telw-ic-1-ae0-0.network.virginmedia.net [62.253.174.174]
7 103 ms 112 ms 110 ms 98.159-105-213.static.virginmediabusiness.co.uk[213.105.159.98]
8 105 ms 111 ms 127 ms 178.79.195.94
9 151 ms 117 ms 106 ms cdn-178-79-211-254.lon.llnw.net [178.79.211.254]
now below with Modem Mode
C:\Users\Francis>ping bbc.co.uk -n 80
Pinging bbc.co.uk [212.58.246.78] with 32 bytes of data:
Reply from 212.58.246.78: bytes=32 time=181ms TTL=53
Reply from 212.58.246.78: bytes=32 time=28ms TTL=53
Reply from 212.58.246.78: bytes=32 time=74ms TTL=53
Reply from 212.58.246.78: bytes=32 time=23ms TTL=53
Reply from 212.58.246.78: bytes=32 time=97ms TTL=53
Reply from 212.58.246.78: bytes=32 time=51ms TTL=53
Reply from 212.58.246.78: bytes=32 time=19ms TTL=53
Reply from 212.58.246.78: bytes=32 time=38ms TTL=53
Reply from 212.58.246.78: bytes=32 time=60ms TTL=53
Reply from 212.58.246.78: bytes=32 time=31ms TTL=53
Reply from 212.58.246.78: bytes=32 time=40ms TTL=53
Reply from 212.58.246.78: bytes=32 time=61ms TTL=53
Reply from 212.58.246.78: bytes=32 time=41ms TTL=53
Reply from 212.58.246.78: bytes=32 time=27ms TTL=53
Reply from 212.58.246.78: bytes=32 time=54ms TTL=53
Reply from 212.58.246.78: bytes=32 time=33ms TTL=53
Reply from 212.58.246.78: bytes=32 time=29ms TTL=53
Reply from 212.58.246.78: bytes=32 time=21ms TTL=53
Reply from 212.58.246.78: bytes=32 time=64ms TTL=53
Reply from 212.58.246.78: bytes=32 time=24ms TTL=53
Reply from 212.58.246.78: bytes=32 time=63ms TTL=53
Reply from 212.58.246.78: bytes=32 time=58ms TTL=53
Ping statistics for 212.58.246.78:
Packets: Sent = 32, Received = 32, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 19ms, Maximum = 181ms, Average = 44ms
C:\Users\Francis>ping download.xbox.com -n 80
Pinging msxb.vo.llnwd.net [178.79.211.253] with 32 bytes of data:
Reply from 178.79.211.253: bytes=32 time=110ms TTL=53
Reply from 178.79.211.253: bytes=32 time=119ms TTL=53
Reply from 178.79.211.253: bytes=32 time=98ms TTL=53
Reply from 178.79.211.253: bytes=32 time=132ms TTL=53
Reply from 178.79.211.253: bytes=32 time=105ms TTL=53
Reply from 178.79.211.253: bytes=32 time=126ms TTL=53
Reply from 178.79.211.253: bytes=32 time=150ms TTL=53
Reply from 178.79.211.253: bytes=32 time=109ms TTL=53
Reply from 178.79.211.253: bytes=32 time=266ms TTL=53
Reply from 178.79.211.253: bytes=32 time=111ms TTL=53
Reply from 178.79.211.253: bytes=32 time=236ms TTL=53
Reply from 178.79.211.253: bytes=32 time=136ms TTL=53
Reply from 178.79.211.253: bytes=32 time=200ms TTL=53
Reply from 178.79.211.253: bytes=32 time=139ms TTL=53
Reply from 178.79.211.253: bytes=32 time=130ms TTL=53
Reply from 178.79.211.253: bytes=32 time=117ms TTL=53
Reply from 178.79.211.253: bytes=32 time=106ms TTL=53
Reply from 178.79.211.253: bytes=32 time=112ms TTL=53
Reply from 178.79.211.253: bytes=32 time=125ms TTL=53
Reply from 178.79.211.253: bytes=32 time=149ms TTL=53
Reply from 178.79.211.253: bytes=32 time=103ms TTL=53
Reply from 178.79.211.253: bytes=32 time=129ms TTL=53
Reply from 178.79.211.253: bytes=32 time=118ms TTL=53
Reply from 178.79.211.253: bytes=32 time=131ms TTL=53
Reply from 178.79.211.253: bytes=32 time=141ms TTL=53
Ping statistics for 178.79.211.253:
Packets: Sent = 31, Received = 31, Lost = 0 (0% loss),
Minimum = 98ms, Maximum = 266ms, Average = 130ms
VIVID 100, Hub 3.0
  • 101
  • 10
francisuk1989
Dialled in
Message 4 of 8
Experiencing high ping again today! Is this bad i cant even play the new call of duty beta!!
I have been pinging my local gateway not my public IP but the gateway im on as i cant ping my black hub 3 but as you can see there's an issue with VM side of things! but all im getting from Virgin is everything is fine when is clearly not fine!, You have sent me a new modem (hub 3) as i had the Superhub 2ac but again this failed to do anything for me. Im all Wired not Wireless.
http://www.thinkbroadband.com/ping/share/4aff705324b6f963445934db2c603ab5-23-10-2016.html Sunday 22/10/2016
10;23pm
http://www.speedtest.net/result/5739533140.png
http://www.speedtest.net/result/5739535671.png
Is not the speed im bothered about...is the Ping is so high Smiley Sad
Power levels
Downstream bonded channels Channel Frequency(Hz) Power (dBmV) SNR(dB) Modulation Channel ID
1298750000 1.538.6 256 qam  17
23227500001.7    38.9 256 qam20
33147500001.538.9   256 qam19
43067500001.538.9256 qam18
52907500001.438.9256 qam16
62827500001.438.9256 qam15
72747500001.538.9256 qam14
82667500001.738.9256 qam13
92587500001.738.9256 qam12
10   2507500001.938.9256 qam11
11  242750000    1.938.9256 qam10
12 2347500001.738.9256 qam9
13  226750000238.9256 qam8
14 2187500002.240.3256 qam7
15 2107500002.438.9256 qam6
16 2027500002.738.9256 qam5
17 1947500002.940.9256 qam4
18 1867500003.240.3256 qam3
19 1787500003.440.3256 qam2
20  1707500003.540.3256 qam
1
Channel ID Frequency(Hz) Modulation Power (dBmV) Mode Channel Bandwidth(Hz) Symbol Rate (ksps)
5039400000 ATDMA  43.3  16 qam  64000005120
4946200000ATDMA44  16 qam  64000005120
VIVID 100, Hub 3.0
  • 10.82K
  • 308
  • 631
Message 5 of 8
Morning francisuk1989,
Thanks for getting back to me and I'm sorry for the late response.
There was a fault in your area in regards to SNR which closed down late evening on the day you posted (23rd October). Looking at the network this morning, it is showing as clear with no errors.
How are things your side? Has there been an improvement with the connection?
Speak soon
Sam
  • 101
  • 10
francisuk1989
Dialled in
Message 6 of 8
No!, Its really still slow between 7pm-11pm weekdays and weekends are even worse however sunday would be the worst weekend, I have setup a thinkbroadband on my gateway IP as i cant ping my local Hub 3 http://www.thinkbroadband.com/ping/share/b14983b1ad0dc95347c32367480a043a.html there a problem somewhere from me to my local node, If virgin media re saying my local CMTS is clear then theres a issue somewhere along the line
cpc1-finc17-2-0-gw.4-2cpc1-finc17-2-0-gw.4-2
traceroute hub 3traceroute hub 3
VIVID 100, Hub 3.0
  • 101
  • 10
francisuk1989
Dialled in
Message 7 of 8
Having a quick noisy in my hub 3 network logs and there's a few failures i see.
Date And Time Error Number Event Description
2016-11-06 11:28:48.00 82000900 B-INIT-RNG Failure - Retries exceeded;CM-MAC=c5:xx:xx:xx:xx
2016-11-06 11:28:51.00 82000200 No Ranging Response received - T3 time-out
this is happening between 2016-11-06 12:07:50 to 2016-11-06 12:14:48
Also i have notice that the power levels on my modem have been dropped but dont affect on my speed/nor ping with my package been 50Mb http://www.speedtest.net/result/5780199096.png and from another speediest website http://www.thinkbroadband.com/speedtest/results.html?id=147856173619975343921
(dBmV) SNR
1 298750000 2.2 38.6 256 qam 17
2 322750000 2.4 38.9 256 qam 20
3 314750000 2.2 38.9 256 qam 19
4 306750000 2.2 38.9 256 qam 18
5 290750000 2 38.9 256 qam 16
6 282750000 2 38.9 256 qam 15
7 274750000 2 40.3 256 qam 14
8 266750000 2.5 38.9 256 qam 13
9 258750000 2.4 38.9 256 qam 12
10 250750000 2.5 40.3 256 qam 11
11 242750000 2.5 38.9 256 qam 10
12 234750000 2.4 38.9 256 qam 9
13 226750000 2.5 38.9 256 qam 8
14 218750000 2.9 40.3 256 qam 7
15 210750000 3 38.9 256 qam 6
16 202750000 3.2 40.3 256 qam 5
17 194750000 3.5 40.3 256 qam 4
18 186750000 3.7 40.3 256 qam 3
19 178750000 4 40.3 256 qam 2
20 170750000 4 40.3 256 qam 1
however the connection has improved, There was a tiny bit of lag now and then however its not worse then it was Smiley Happy so this seem to be fixed 07/11/2016
VIVID 100, Hub 3.0
  • 10.82K
  • 308
  • 631
Message 8 of 8
Hi francisuk1989,
Thanks for the reply.
From the last BQM you posted the connection is much better, which is great Smiley Happy
The information you posted from the router's network log, these are fine. If you are seeing T3 time-outs, MDD time-outs then post the entire log for us to take a look.
In the meantime, monitor the connection and if there are any further issues by all means let me know.
Sam
