  • 117
tonytango
Message 1 of 10
speed please
Why is it that every night at 7pm the internet speed drops from over 150mbps to below 20mbps ?
i know that people come home from work/school but the speed should not drop that much
  • 3.01K
  • 383
  • 952
Message 2 of 10
Re: speed please
Slow speeds at peak times (typically 4pm-11pm weekdays and weekends) but full speed at off peak times is normally a symptom of high utilisation/contention in your area.
Somebody from the VM forum team should be along in a few days (up to a week) to check your connection and can confirm if there is a known issue with your segment of the network. If that is the case they should provide a fault reference and pass your details onto another team who should inform you about your credit options for the lack of service via a PM. They should also be able to provide a review date for the fault. Note that it is a review date not an expected fix date and some customers affected by this kind of issue have been waiting over a year for a fix.
______________________
Scott
  • 8.36K
  • 362
  • 590
Message 3 of 10
Re: speed please
Hi tonytango,
Thanks for posting!
Really sorry to hear you're experiencing speed issues.
I've located your account and everything is looking great at the moment. No network issues in your area and all levels are within spec. Are you still experiencing slow speeds? Do you connect wired or wirelessly?
Speak soon Smiley Very Happy
Josh
  • 117
tonytango
Message 4 of 10
Re: speed please
it make's no difference weather i connect wireless or wired the speed still drop's at 7pm
  • 10.69K
  • 314
  • 657
Message 5 of 10
Re: speed please
Hello tonytango,
Thanks for getting back to us Smiley Happy
I've just double checked the usage in your area and it's currently looking fine. Are you able to set-up a TBB monitor up for us so we can get a more detailed report about what is happening with your connection.
Hope to hear back from you again soon,
Take care.
Heather_J
  • 117
tonytango
Message 6 of 10
Re: speed please
Hi,no i am not going to set up a tbb monitor as the last time i installed that i had to completely restore my laptop.
this is the speed i am getting at the moment  http://www.speedtest.net/my-result/6020286132
  • 22.27K
  • 852
  • 3.24K
Message 7 of 10
Re: speed please
tbb isn't something you install its a online service. you dont need to make any chances to your laptop. If you did last time you didn't setup the right thing.
  • 117
tonytango
Message 8 of 10
Re: speed please
well i am not going to use it again
  • 22.27K
  • 852
  • 3.24K
Message 9 of 10
Re: speed please
OK, good luck
  • 8.36K
  • 362
  • 590
Message 10 of 10
Re: speed please
Hi tonytango,
Sorry again for the trouble.
If you're not a fan of the broadband quality monitor, that's no problem!
I'd like you to try running a speed test with the hub in Modem Mode to see if the results differ at all.
Josh
