  • 10
baskcm
Message 1 of 18
speed drop
hi im currently on vivid 150 and my speed seems to be going all over the place i used to get well over 100 mb now im lucky to get over 34mb here are the logs from the router any suggestions would be appreciative
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8 243000000 Hz 203000000 Hz 211000000 Hz 219000000 Hz 227000000 Hz 235000000 Hz 251000000 Hz 259000000 Hz Locked Locked Locked Locked Locked Locked Locked Locked 6 1 2 3 4 5 7 8 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 -1.0 dBmV -0.1 dBmV -0.6 dBmV -1.1 dBmV -2.0 dBmV -1.0 dBmV -1.1 dBmV -1.3 dBmV 39.9 dB 40.8 dB 40.4 dB 40.4 dB 39.9 dB 39.9 dB 39.9 dB 39.9 dB
Frequency (Hz)
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Channel ID
Modulation
Symbol Rate (Msym/sec)
Interleave Depth
Power Level (dBmV)
RxMER (dB)
Upstream   US-1 US-2 US-3 US-4 2.0 2.0 N/A N/A 3 4 N/A N/A 32600000 Hz 25800000 Hz N/A N/A Success Success N/A N/A QAM64 QAM64 N/A N/A 5120000 5120000 N/A N/A 128 128 N/A N/A 47.8 dBmV 47.3 dBmV N/A N/A 0 0 N/A N/A 0 0 N/A N/A 1 1 N/A N/A 0 0 N/A N/A
Channel Type
Channel ID
Frequency (Hz)
Ranging Status
Modulation
Symbol Rate (Sym/sec)
Mini-Slot Size
Power Level (dBmV)
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
  • 10
baskcm
Message 2 of 18
Re: speed drop
any update to this since its still happening drastic speed reduction
  • 9.59K
  • 826
  • 2.01K
Message 3 of 18
Re: speed drop
Are you connecting wired or wirelessly?
If wireless try a wired connection directly to the hub.
  • 10
baskcm
Message 4 of 18
Re: speed drop
its connected to the hub with a wire its right next to the computer as well
  • 9.59K
  • 826
  • 2.01K
Message 5 of 18
Re: speed drop
Are the speeds poor all the time or only during evening peak times?
Hopefully, someone from the @ModTeam should pick this soon and take a closer look as you have been waiting quite a while.
  • 10
baskcm
Message 6 of 18
Re: speed drop
its random I didn't have a single problem with speed it can happen throughout the day heck one time it dropped to 0.5 I've changed wireless channel to stop it interfering with other people wifi I'm just at  a loss why its started dipping now
  • 6.91K
  • 186
  • 455
Message 7 of 18
Re: speed drop
Thanks for posting baskcm,
Sorry to hear about the connection issue experienced.
I've had a look into this and there does appear to be a potential issue in your area concerning SNR. This type of thing is known to cause inconsistencies with your broadband performance.
I have flagged this over with Networks to investigate further and will make sure to get back to you with an update regarding this ASAP.
Having had a look at the equipment levels, there doesn't appear to be any cause for concern with the hardware.
Speak to you soon,
Nat_J
  • 10
baskcm
Message 8 of 18
Re: speed drop
thank you very much never had a problem with speed until now i shall look forward to your reply
  • 14.48K
  • 641
  • 1.46K
Moderator
Moderator
Message 9 of 18
Re: speed drop
Hi Baskcm,
Thanks for waiting, the SNR fault that Nat raised was closed yesterday though upon rechecking your connection I did notice that your upstream power levels are a little on the high side. Could you give your hub a reboot and see if they return to normal? Also how is your connection since the fault closed? Any improvement?
  • 10
baskcm
Message 10 of 18
Re: speed drop
speed has increased since last time we did have a power cut last night so ill reset it again
reset the router
Upstream   US-1 US-2 US-3 US-4 2.0 2.0 N/A N/A 3 4 N/A N/A 32600000 Hz 25800000 Hz N/A N/A Success Success N/A N/A QAM64 QAM64 N/A N/A 5120000 5120000 N/A N/A 128 128 N/A N/A 46.8 dBmV 46.3 dBmV N/A N/A 0 0 N/A N/A 0 0 N/A N/A 0 0 N/A N/A 0 0 N/A N/A
Channel Type
Channel ID
Frequency (Hz)
Ranging Status
Modulation
Mini-Slot Size
Power Level (dBmV)
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
