Peach777
speed boost available but can't access it
when i put my post code into the checker it says my speed boost is available now. But when i access my account it says its on its way???
  • 5.34K
  • 270
  • 1.17K
Re: speed boost available but can't access it
End of the month, takes a while for the post code checked to be updated.
If it's available you will have it on your MyVirginMedia. You can always call up and see what the status of it is.
I think your name rings a bell from another thread where you are suffering from peak time utilization? If that is you I'm remembering then: they will not process an upgrade in an area suffering from peak time utilization. You wouldn't get any benefit whatsoever anyway.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
