  • 17
AudioDetective
slow wireless router
 I'm still having terrible internet speeds via my wireless super router so I connected via Ethernet cable and "heh presto" I'm now reading 63mb download so I'm assuming something to do with the wireless side (I'm on mac btw) I am unable to reach my router to connect directly as I work in a different room so this causes a problem for me.
Could someone please suggest a solution?
Gerry.
  • 5.67K
  • 291
  • 1.25K
Re: slow wireless router
Move your computer
Get a long Ethernet cable and run it along your skirting boards etc
Don't use wireless
Try powerline adapters.
That's your short list.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 17
AudioDetective
Thank you Shafreya extremely helpful?
  • 5.67K
  • 291
  • 1.25K
Was at work so didn't have time for long detailed answers but that is your options to get the speed.
With powerline adapters it depends on your homes electrics as to what speed you will get (and the quality of the adapter itself)
Another option is getting a good 3rd party AC router and getting an AC network card for your MAC.
