gbleewal
slow broadband
Why is my broadband speed slowing down to an average of 5mbps when I have vivid 200.
I am in area 20.
Helpful Answers
  • 3.01K
  • 383
  • 952
Re: slow broadband
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
If wired off peak speeds are slow the some hub stats might help. Go to http://192.168.0.1/ (or http://192.168.100.1/ if you are in modem mode) to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP or MAC address in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take 7-10 days) and run checks on your line.
______________________
Scott
All Replies
  • 3.01K
  • 383
  • 952
Re: slow broadband
Scott
gbleewal
Re: slow broadband
Hi SCA1972,
Thanks for your reply, here are what you requested I think.
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1298750000-0.538.9256 qam21
2322750000-0.538.9256 qam24
3314750000-0.538.9256 qam23
4306750000-0.540.3256 qam22
5290750000-0.538.9256 qam20
6282750000-0.538.6256 qam19
7274750000040.3256 qam18
82667500000.240.3256 qam17
92587500000.240.9256 qam16
102507500000.240.9256 qam15
11242750000040.3256 qam14
12234750000-0.240.3256 qam13
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
4146200000ATDMA4364 qam64000005120
4332600000ATDMA4364 qam6400000
5120
Date And Time Error Number Event Description
2017-01-08 08:05:19.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-09 15:35:22.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-12 15:46:35.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-12 19:44:00.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-12 22:15:22.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-12 22:26:40.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-13 06:58:10.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-13 06:58:10.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-13 06:58:11.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-13 06:58:16.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-14 13:31:03.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-17 17:56:37.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-19 01:26:41.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-21 16:53:36.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-22 01:37:55.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-22 17:24:25.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-22 18:51:30.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-22 21:19:13.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-26 04:17:42.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.01K
  • 383
  • 952
Re: slow broadband
Power levels look OK.  A few errors in the log but the worst ones are from two weeks ago and the more recent ones are several days apart so not sure they are significant.
As you have not directly answered my questions, can I just confirm that you are testing with a wired connection and it is slow even at off peak times?
Scott
gbleewal
Re: slow broadband
Just done the tests again.
WIFI = Ping 44ms  Down 5.5Mbps Up 12.10Mbps.
Wired = Ping 36ms Down 7.13 Mbps Up 12.25Mbps
  • 9.39K
  • 313
  • 1.01K
Re: slow broadband
Hello gbleewal
Welcome to our forum, I am sorry you are having problems with slow speed and lag. At the moment your connection is looking good, hub and line all nicely within spec and error free. The area traffic does have a few spikes in the evening and if you hit one of these it may impact you however overall it is not quite at our threshold for escalation, we will keep an eye on it. How are your speeds off peak, say in the morning or afternoon any better?
Thank you
Nicola
Virgin Media Forum Team
