  • 7
Funsponge
"Vivid200" - Almost ten times faster than ISDN!
6701781045
This costs £43.74 a month...
  • 10.53K
  • 295
  • 620
Re: "Vivid200" - Almost ten times faster than ISDN!
Hi there Funsponge,
Thanks for taking the time to post on the community.
Sorry to see you are experiencing slow broadband speeds.
From checking your connection, there is a high peak time traffic fault in your area which is causing slow speeds. The reference number is F004944283 and has a review date of 6th December. As this is a review date it can be subject to change.
Do you achieve these speeds at all times of the day or just during peak hours?
Are you testing through a wired or wireless connection?
Hope to hear from you soon
Sam
  • 171
  • 28
TimR
Up to speed
That will of course be 6th December 2019 !
Chinchin
Struggling VM BB [Over Utilisation Fault, Fix date 17th November 2135 ]
VM Telephone
Sky Q UHD Multiscreen
