  • 39
pompeyneil
Message 1 of 17
pooor download speed PO2
Paying for 200mb have been getting a lot less since I've been checking this week. Less than 100mb around 6 a.m. now at 40mb at 5.45 pm.....what is the reason?
  • 9.97K
  • 291
  • 624
Message 2 of 17
Re: pooor download speed PO2
Hey pompeyneil,
Sorry to hear you're getting slow speeds, this can be annoying.
I've taken a look at your connection and the local area and everything looks okay for now.
Have you been testing the speeds on a wireless or a hard-wired device? If you've used wireless previously, please test again with an Ethernet cable.
Hope to hear back from you soon,
Take care.
Heather_J
  • 39
pompeyneil
Message 3 of 17
It's hard wired and I've been using speedtest.net for the results as well as other methods. 140Mbps is the highest I have recently, at 8a.m. on a Sunday morning so not the busiest time of day.
  • 10.82K
  • 308
  • 631
Message 4 of 17
Hi pompeyneil,
Thanks for getting back to us.
I appreciate all the checks you have competed so far, however you are still not achieving the up to 200 Mbps broadband speeds.
Looking at your connection, I can see that you are using the Super Hub in modem mode. Are you using your own router at all? With the speed test you completed was that hard-wired direct to the Super Hub or your equipment? If you can complete a speed test direct to the Super Hub and whilst the PC/laptop is in Safe Mode with Networking, that will be helpful. Also if you can post a copy/link of the results that would be great.
Speak soon
Sam
  • 39
pompeyneil
Message 5 of 17
[URL=http://www.speedtest.net/my-result/5780984223][IMG]http://www.speedtest.net/result/5780984223.png[/I...]
Not sure if I've copied the link properly, speed was 87.33 down and 12.34 up at 08.45 a.m. on a Tuesday morning, hard wired into the Superhub only but not using safe mode and networking as for some reason I couldn't get the networking part going. Yes, I do have another router plugged in for gaming .and the results are the same.
  • 10.82K
  • 308
  • 631
Message 6 of 17
Morning pompeyneil,
Thanks for posting your speedtest results, I appreciate it.
Just for my understanding, since being on 200 Mbps, have you been able to achieve these speeds at all?
On the PC/laptop you are testing with does the LAN card still show as a gigabit?
Speak soon
Sam
  • 39
pompeyneil
Message 7 of 17
Yes I have had 200Mbps and I don't know how to find out the other info but the laptop is only 4 months old and fully updated, I also get the same results on my wifes laptop.
  • 10.82K
  • 308
  • 631
Message 8 of 17
Evening pompeyneil,
Thanks for getting back to me.
To check the LAN card speed, on the laptop go into Control Panel > Networking & Sharing Centre > Where is shows Connection - Local Area Connection click into View Status. Where is shows Link Speed, let me know what is written here please.
Speak soon
Sam
  • 39
pompeyneil
Message 9 of 17
It says 100 Mbps and am getting speeds of 55-95 on laptop and Xbox one both of which used to register 200+ on occasions.
  • 39
pompeyneil
Message 10 of 17
Down to 40-50 Mbps now on laptop and Xbox One S at 06.40 on Monday morning.
