  • 225
James908
Message 1 of 9
less than half the download on uplay and origin and the same issues as before on streaming sites
here the evidence of the slow speeds
  • 225
James908
Message 2 of 9
Re: less than half the download on uplay and origin and the same issues as before on streaming sites
its still slow at 20 past 11 at night
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID48729
Max Traffic Rate230000000 bps
Max Traffic Burst42600 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID66995
Max Traffic Rate12700000 bps
Max Traffic Burst16320 bytes
Max Concatenated Burst16320 bytes
Scheduling TypeBest Effort
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)306750000266750000274750000282750000290750000298750000314750000322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID2217181920212324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)3.175.235.054.243.773.522.562.09
RxMER (dB)37.6437.9438.2637.6437.9437.9437.9437.64
Pre RS Errors
297379299936999924952937
Post RS Errors
275288290933997924947932
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID52N/AN/A49
Frequency (Hz)25800000N/AN/A46200000
Ranging StatusSuccessOtherOtherSuccess
Modulation32QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)38.00N/AN/A40.50
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 225
James908
Message 3 of 9
heres downloading on thinkbroadband terrible
here's downloading heaven benchmark
again poor speeds
downloading on nvidia website
  • 225
James908
Message 4 of 9
Re: and the same issues as before on streaming sites and
  • 225
James908
Message 5 of 9
  • 225
James908
Message 6 of 9
this is properly to with the poor HTTP download speed it just started happening Ive already posted on there , but it used to only happen at peak times on video sites then not at all for a mouth then this, now some are affected worse than other and also downloads seem to be slow except downloading on steam or origin which overall still isn't solid as it was a few days a go
and also speed test gives a false result which is misleading and takes longer to load also youtube videos dont load straight away
http://www.speedtest.net/result/5894940074.png
  • 225
James908
Message 7 of 9
Its been three weeks and this problem is still happerning and somebody on the forum respond its been 3weeks yet newer posts are getting responded to
  • 67
  • 25
Hydrops
Dialled in
Message 8 of 9
Not going to lie but if they haven't responded in 3 weeks its about time you ditch and switch.
I can almost guarantee you that when one of the mongrels post they inform you that they are sorry and that there is a fault in your area due to over utilisation. They'll give you a randomly generated review date and then when this date arrives they'll give you a additional date that is pulled out of thin air.
Getting consistently shafted by highly fluctuated ping during "peek" all daylight hours.
  • 13.02K
  • 371
  • 1.06K
Moderator
Moderator
Message 9 of 9
Hi James908,
I've replied in your other thread here, if you could avoid duplicating posts it avoids confusion and means we can get to them sooner.
Ralph_R
Forum Moderator
