  • 18
penhilchippyman
Message 1 of 5
internet speed inconsistant
I have just upgraded to virgin 100 mgb connection , from a 50 mgb connection, the reason i upgraded was because when i am streaming video  it keeps bufferering all the time, It still bufferering continualy all day long whenever i try it.
i have done a lot of speed tests, 1 minute i get  speed test of 95 then 10 seconds later another test and it is aprox  8  mgb this is like this all day long no consistancy  what so ever.
I use speed.net test ,
  • 8.3K
  • 521
  • 2.3K
Message 2 of 5
Re: internet speed inconsistant
How are you connecting to the HUB?
Wired? Wireless?
  • 10.82K
  • 308
  • 631
Message 3 of 5
Hi penhilchippyman,
Thanks for taking the time to post on the community.
Sorry to read that you are having issues with the broadband speeds.
I've taken a look at your connection, the line and hub have come back as fine. The network segment is running stable with no errors.
As Kippies mentioned are you testing through a wired or wireless connection? If wireless can you try through wired please?
Does this happen on just the one device or all?
Let us know how you get on
Sam
  • 18
penhilchippyman
Message 4 of 5
Had 2 engineers out and both said ok , Even though they put new cable and new router in, Made no differerence at all, one minute getting 50 next min getting 6, was waiting on another engineer to come ,Got fed up waiting so checked all cables coming into house, Guess what it was a loose virgin mediia cable that connects to router
PLEASE give me a job
  • 10.82K
  • 308
  • 631
Message 5 of 5
Evening penhilchippyman,
Thanks for getting back to me.
I am happy to hear that you found the cause of the issue, even though you had engineer visits.
Monitor the connection and if there are any further issues, by all means get back in touch.
Take care
Sam
