  • 8
morrowj04
identify certain attributes of my VM connection.
Hi Im wondering if there is an easy way to identify certain attributes of my VM connection.
  1. Is my Connection FTTP/H or FTTC?
  2. Could i connect using fully fibre to the VM network?
    1. Currently Coaxial internal to VM equipment
    2. Would like to run full fibre through my home.
Helpful Answers
  • 22.28K
  • 855
  • 3.24K
Re: identify certain attributes of my VM connection.
1) its FTTC
2) No
3) from the green box is coax. Fibre to a main node in the area. then coax to the other green boxes and then coax from that box to you
4) you can run fibre but you will be limited to coax from the SH so you will need a switch that can connect to the SH by ethernet and then fibre though your home
All Replies
  • 22.28K
  • 855
  • 3.24K
1) its FTTC
2) No
