guitarbomber
i am on vivid 200 with a super hub 1.0 should i upgrade to 3.0?
  • 10.82K
  • 308
  • 632
Re: i am on vivid 200 with a super hub 1.0 should i upgrade to 3.0?
Hi there guitarbomber,
I appreciate your query in regards to the equipment you have whilst connected at 200 Mbps broadband speeds.
Looking at your account, the equipment you have is fine for the speeds you are on. If you would like to upgrade to the Hub 3.0, by all means give us a ring on either 150 or 0345 454 1111 to discuss this further.
Sam
