masenc
hub 3.0 speed
Hiya
so iv just set my hub 3.0 up today, all nice and updated and should be running up to 200mbps
on wifi on my phone, its crap, but i think its just the device as it seems to only hit 51 on the ofcom app
however using my laptop i get a very sexy 130mbs on wifi, well between 100 and 130, which im happy with, cant wait to test it on my pc! however when i plugged my laptop up with a new ethernet cable, cat 6, only been using it a few weeks as was originally using sky hub 3.0
however on ethernet i cant get anything over 10mbs, uploads fine, usually hits 9...on wifi it hits about 15
tried turning hub on and off, other ethernet ports and cables, but im stuck on 10, even ran diagnostics on homepage and it says theres an issue
any fixes?
Diagnostic Results...
 WiFisignalstrength of **:**:**:**:**:** is -46dBm.
Wirelessprimary network is Enabled on 2.4GHz.
Wirelessprimary network is Enabled on 5GHz.
Internetconnection is good.
Telephoneline 1 is disabled
Telephoneline 2 is disabled
Wired client on port 1 is running at 10 Mbps.
Device connected on port 1 is running at a lower speed of 10 Mbps and is not utilizing the full available speed.
Wireless guest network is Disabled on 2.4GHz.
Wireless guest network is Disabled on 5GHz.
  • 30
awalos
Re: hub 3.0 speed
I also have a problem. I start Submit a Claim https://www.cedr.com/cisas/make-a-complaint/
masenc
Re: hub 3.0 speed
also ontop of this if i leave my living room, my laptop goes from 110-130 to 25
my main pc gets 10
my phone gets about 36
so theres something defo here thats abit off
