  • 8
ahsih
high ping ,download speed and upload speed is fine?
Hi there,
Basically, I have some issues with my broadband recently, I am getting high ping. But my download speed and upload speed are fine.
Downstream Acquisition Locked
Primary Frequency 251000000 Hz
DHCP Done
TFTP Done
Time Of Day 23:24:09 GMT
Security BPI+
Counters T1,T2,T3,T4,Sync,Resets 000,000,000,000,000,000
Internet Connection IP Address Status
WAN IP Address 92.237.196.199
Lease Time Remaining 6 days 12h:35m:00s
Expiry Sun 22 Jan 11:59
Current Network Time Sun 15 Jan 23:24 GMT
Downstream Channels Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked 7 251000000 Hz 256 QAM 2.3 dBmV  38.3 dB 277 276
Locked 1 203000000 Hz 256 QAM 2.8 dBmV  38.6 dB 289 285
Locked 2 211000000 Hz 256 QAM 2.6 dBmV  38.6 dB 281 280
Locked 3 219000000 Hz 256 QAM 2.4 dBmV  38.3 dB 291 290
Locked 4 227000000 Hz 256 QAM 2.2 dBmV  38.6 dB 279 277
Locked 5 235000000 Hz 256 QAM 2.1 dBmV  39.9 dB 278 275
Locked 6 243000000 Hz 256 QAM 2.2 dBmV  37.6 dB 297 294
Locked 8 259000000 Hz 256 QAM 2.2 dBmV  39.9 dB 299 298
To reset the Pre and Post RS error counts please use the Downstream screen under the router status screen available from the login page.
Upstream Channels Lock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
NotLocked 0 0 Hz   0 dBmV     0 Ksym/sec
Locked 3 32600000 Hz ATDMA 39.0 dBmV 16QAM 6400000 Hz 5120 Ksym/sec
Locked 4 25800000 Hz ATDMA 37.8 dBmV 16QAM 6400000 Hz 5120 Ksym/sec
Network Log:
15/01/2017 23:43:13 GMT 15/01/2017 23:43:13 GMT Warning (5) 66050310 Auth Success - Web login successful.
15/01/2017 23:43:01 GMT 15/01/2017 23:43:01 GMT Warning (5) 90000200 CSFR Detect - Expired Content Submitted ; LAN Interface
15/01/2017 23:31:34 GMT 15/01/2017 23:31:34 GMT Error (4) 68010302 DHCP WAN IP - *******
15/01/2017 23:30:25 GMT 15/01/2017 23:30:25 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
15/01/2017 23:29:20 GMT 15/01/2017 23:29:20 GMT Notice (6) 69011200 SW download Successful - Via Config file
15/01/2017 23:26:29 GMT 15/01/2017 23:26:29 GMT Warning (5) 66050310 Auth Success - Web login successful.
15/01/2017 23:26:25 GMT 15/01/2017 23:26:25 GMT Warning (5) 66050300 Auth Fail - Web login failed.
15/01/2017 23:26:23 GMT 15/01/2017 23:26:23 GMT Warning (5) 90000200 CSFR Detect - Expired Content Submitted ; LAN Interface
15/01/2017 23:21:18 GMT 15/01/2017 23:21:18 GMT Warning (5) 66050310 Auth Success - Web login successful.
15/01/2017 23:20:21 GMT 15/01/2017 23:20:21 GMT Error (4) 68010302 DHCP WAN IP - *********
15/01/2017 23:19:22 GMT 15/01/2017 23:19:22 GMT Notice (6) 69010200 SW Download INIT - Via Config file tftp file-********
15/01/2017 23:19:07 GMT 15/01/2017 23:19:07 GMT Error (4) 68000407 TOD established
15/01/2017 23:16:19 GMT 15/01/2017 23:16:19 GMT Warning (5) 66050310 Auth Success - Web login successful.
15/01/2017 23:16:15 GMT 15/01/2017 23:16:15 GMT Warning (5) 66050300 Auth Fail - Web login failed.
15/01/2017 15:27:47 GMT 15/01/2017 15:27:47 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
15/01/2017 15:27:45 GMT 15/01/2017 15:27:45 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
15/01/2017 15:27:44 GMT 15/01/2017 15:27:44 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
15/01/2017 15:27:43 GMT 15/01/2017 15:27:43 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 8.62K
  • 552
  • 2.38K
Re: high ping ,download speed and upload speed is fine?
High ping to what?
Can you post a couple of traceroutes?
How are you connecting to the HUB? Wired? Wireless?
