dagwells
Message 1 of 10
dreaded Speed question
Area 28, Big Kahuna pkg. Been averaging 10-14mb WIFI download speed for many months now. Is this acceptable, or should I get on the phone to Virgin and look for a fix?
  • 5.66K
  • 291
  • 1.25K
Message 2 of 10
Re: dreaded Speed question
What do you get wired?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
dagwells
Message 3 of 10
A max of about 22mb, but as it's an older imac, i figured that might be the problem.
  • 13.16K
  • 377
  • 1.08K
Moderator
Moderator
Message 4 of 10
Hi dagwells,
Just though I'd add that diagnostics on your hub and network segment throw up a clean bill of health, so good speeds should be very achievable.....are you able to test your connection on any other PC or gigabit capable device?
Ralph_R
Forum Moderator
  • 20
  • 6
Codpiece79
Message 5 of 10
Good look with the speeds,do you get the poor speeds of an evening if so good luck to you they will say it's due to high utilisation and give you a review date,I'd leave now if you have the chance I've had poor speeds of 4mb in the evenings but paying for 100mb,I've had this since April last year,so I had enough and phoned cancellations but they said they will get a broadband tech guy to call me on the 18th of January who won't read from a script and will tell me it as it is,if there is no resolve I'm going to bt.
dagwells
Message 6 of 10
I recently noticed a Virgin engineer at the main street box, so re-tested the older Mac - it showed 80mb download / 9mb upload, so I was satisfied with that. Hand held devices (iPhone 6 / iPad) still showed approx 14mb download, even right beside the router so the issue must be with the Virgin modem?
  • 5.66K
  • 291
  • 1.25K
Message 7 of 10
The issue will be to do with your wireless environment. As everyone's is different no ISP guarantees wireless speeds.
You've had a reply from VM saying nothing is wrong on the hub or network segment so that is pointing at wireless being the problem with your other devices.
  • 20
  • 6
Codpiece79
Message 8 of 10
We will see how long it lasts until he gets the same **bleep** from virgin.
  • 5.66K
  • 291
  • 1.25K
Message 9 of 10
Just depends on the locality. I've never had any peak time issues and I doubt I will (I live amongst retirement homes)
  • 20
  • 6
Codpiece79
Message 10 of 10
You must be one of the lucky ones then,having read the forums daily I can see it's a national problem.
