dialupisback
download speeds of less than 10mps
Hi Im supposed to be on up to 200 but lucky if I get 5 my upload is between 6 and 8 and I've not changed anything can I request a tech support to look at my connection please?
  • 8.28K
  • 514
  • 2.3K
Re: download speeds of less than 10mps
How are you testing? Wired? Wireless? On what device? PC/laptop/phone?
  • 15
  • 12
Proteus
Getting the exact same problem in Liverpool. Have tested on two computers, have disabled wireless and tested only wired, have reset router, have tried speedtest.net to different servers, have used the service status page to test for problems but it just said wait 10 minutes and now i can't test again.
It is definitely an issue down your end. I am unable to call Virgin right now, can you check your end or do anything? Thanks for your time.
  • 8.28K
  • 514
  • 2.3K
AS I dont work for VM, I cant test anything their end, Im just a customer same as you, albeit a long term one.
Liverpool is pretty famous for overutilisation issues with VM... set up a BQM
 HERE
 Run it for say 24 hrs, and post the result.
Dont forget youll need to make sure your super hub is configured to reply to ICMP echo requests...
dialupisback
Hi thanks for the reply I am getting the same results testing wireless and wired and across a range of devices it's been like it for weeks now. The connection should be able to handle internet browsing gaming and on demand streaming but it's struggling now whereas a month ago it wasnt
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi dialupisback,
Thanks for getting in touch to let us know that you've been having slow speeds of less than 10 Mbps. I apologise for any inconvenience caused.
I have tested things from here and I can see some T4 time outs inside the Hubs logs and in order to get this resolved I would like to arrange for one of our engineers to attend and investigate things further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking, please respond to me there and I'll get this sorted for you.
Take care,
Adam.
