FSH
Message 1 of 5
correct internet speed?
my account states I should be able to receive 50mbps even standing next to router I receive 29 Mbps & 3.18 Mbps upload is this correct ?
Helpful Answers
  • 9.01K
  • 760
  • 1.88K
Message 2 of 5
Re: correct internet speed?
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub
All Replies
  • 9.01K
  • 760
  • 1.88K
Message 2 of 5
SmithyW7
Message 3 of 5
I'd say that is pretty normal for up to 50MB, weekends mine will occasionally swoop down to 10-15MB (still usable), but during the week I'm at around 24MB down 3MB up with a ping of about 8ms. Very rarely will I get 45MB or more and I'm someone who's online ALOT so I'd know :X
I know people on the 100MB+ packages that get less than we do so guess we should consider ourselves lucky lol
FSH
Message 4 of 5
Hi Thanks for that yes when wired I get 50mbps .On the wifi it's less depending how far away from modem I get .
Cheers
FSH
Message 5 of 5
Yes thank you just put on wired computer & it's 50, drops down on wifi so it's sounds as if we are lucky cheers
