  • 8
ibbo1977
Message 1 of 13
broadband speeds not above 100mb
just checked my broadband speed and not even near 100mb but have got vivid 200mb.
any suggestions please.
  • 9.47K
  • 649
  • 1.8K
Message 2 of 13
Re: broadband speeds not above 100mb
how are you testing - wired or wireless - if wired what is the spec of the lan cable - is the lan card in the pc gigabit
posting the upstream and downstrean levels will also help diagnose problems
____________________
Tony
  • 8
ibbo1977
Message 3 of 13
wired and a cat 6
  • 9.47K
  • 649
  • 1.8K
Message 4 of 13
ibbo1977 wrote:
wired and a cat 6
then post the upstream and downstream levels
Tony
  • 8
ibbo1977
Message 5 of 13
Ping Download Upload
341 ms96.77 Mb/s11.24 Mb/s
Not your provider?
Virgin Cable
80.7.198.195
  • 8
ibbo1977
Message 6 of 13
Test result, 01.12.2016 22:01
Download(Higher is better)
76,0 Mbit/s
Upload(Higher is better)
11,9 Mbit/s
Response (ping)(Lower is better)
53,0 ms
Download in
MP3 for 0,4 sec
CD for 1,2 min
DVD for 8,2 min
  • 9.47K
  • 649
  • 1.8K
Message 7 of 13
log into superhub - 192.168.0.1 - DON'T SIGN IN, click router status  - and post the downstream and upstream figures
Tony
  • 8
ibbo1977
Message 8 of 13
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
825800000ATDMA3916 qam64000005120
732600000ATDMA3916 qam64000005120
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12990000005.638.9256 qam13
2323000000538.9256 qam16
33150000005.338.9256 qam15
43070000005.538.9256 qam14
52910000005.538.9256 qam12
62830000005.538.9256 qam11
72750000005.840.3256 qam10
82670000005.638.6256 qam9
92590000005.638.9256 qam8
102510000006.138.6256 qam7
11243000000838.9256 qam6
122350000008.540.3256 qam5
132270000008.538.9256 qam4
14219000000838.6256 qam3
15211000000838.6256 qam2
162030000007.938.6256 qam1
  • 8.99K
  • 756
  • 1.87K
Message 9 of 13
What device are you connecting with.
Are you connecting directly to the hub?
  • 8
ibbo1977
Message 10 of 13
laptop straight into hub
