  • 17
hannesd
Message 1 of 23
area 20 poor speed
Hello
I moved and had internet installed yesterday, never had issues in the past, now I have consistant 3mbps speed instead of 40-50 during peak hours
area ref 20
6164797459
  • 12
biskitbeetle
Message 2 of 23
Re: area 20 poor speed
Area 20  (royton) here too, looks like they are having problems not just you.
  • 17
hannesd
Message 3 of 23
thing was i was also in area 20 before i moved if i m not mistaken. so is this depended on the whole area or is it something to do with the street ? and how to fix it
  • 12
biskitbeetle
Message 4 of 23
according to virgin server status looks like its going to be fixed by 27th.
  • 17
hannesd
Message 5 of 23
what status? link ?
  • 12
biskitbeetle
Message 6 of 23
Also down detector seems to be showing increasing  reports from the area 20
  • 12
biskitbeetle
Message 7 of 23
you need to login then you can run a test on your line here.
https://my.virginmedia.com/faults/service-status
  • 17
hannesd
Message 8 of 23
mine says no issues so pretty sure that is just costumer support that flagged your account and promises you it ll be fixed on the 27th
  • 12
biskitbeetle
Message 9 of 23
http://downdetector.co.uk/problems/virgin-media
if you read the comments on here you will see that multiple virgin customers are having problems also quite a few in area 20
  • 12
biskitbeetle
Message 10 of 23
