jwinterbourne
Message 1 of 8
Zero upload speed
I believe I have the same problem as in this post here:
http://community.virginmedia.com/t5/Speed/No-Upload-Speed/td-p/3127566
I have the 200mb fibre connection, and I get consistently >150Mbit/s down and less than 10 KB/s up (correct units). I have spoken with the support line and they do not seem to recognise this type of fault, generally insisting that I must have 4Mbit/s. They have tried resetting the router in various ways and placed it into various modes (including modem mode and safe mode) to no avail.
My router stats are included below.
Is there anything I can do to resolve this?
Many thanks,
Jeff Winterbourne
Downstream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12990000007.937.6256 qam17
23230000007.537.6256 qam20
33150000007.537.3256 qam19
43070000007.337.3256 qam18
52910000007.537.3256 qam16
62830000007.837.3256 qam15
72750000007.637.3256 qam14
82670000007.937.3256 qam13
92590000007.637.3256 qam12
102510000007.537.3256 qam11
112430000007.437.3256 qam10
122350000007.137.3256 qam9
132270000007.437.3256 qam8
142190000007.537.3256 qam7
152110000007.537256 qam6
162030000007.537.3256 qam5
171950000007.537.3256 qam4
181870000007.537.3256 qam3
191790000007.437.3256 qam2
201710000007.537.3256 qam1
Upstream
Channel ID Frequency(Hz) Mode Power
7831000000ATDMA38.816 qam64000005120
7924400000ATDMA38.816 qam64000005120
Log
Date And Time Error Number Event Description
2017-02-25 08:38:06.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 09:19:19.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 09:30:37.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 10:37:36.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 10:55:56.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-28 15:02:06.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-02 06:25:55.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-03 13:55:57.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-05 12:18:07.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-08 13:20:49.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-09 18:34:21.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-09 18:52:41.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-09 20:50:52.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-10 18:32:58.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-12 21:02:07.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-13 16:43:26.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-14 16:49:38.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-18 06:48:32.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-19 12:49:58.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-19 19:02:24.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mark_tw
Message 2 of 8
Re: Zero upload speed
I am having the same issue.  upload speed of either 0 or 0.8mbs.
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8 251000000 Hz 219000000 Hz 227000000 Hz 235000000 Hz 243000000 Hz 259000000 Hz 267000000 Hz 275000000 Hz Locked Locked Locked Locked Locked Locked Locked Locked 11 7 8 9 10 12 13 14 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 3.2 dBmV 1.8 dBmV 1.9 dBmV 1.8 dBmV 1.4 dBmV 3.3 dBmV 3.0 dBmV 2.4 dBmV 34.3 dB 33.2 dB 33.9 dB 34.1 dB 34.0 dB 34.5 dB 34.3 dB 34.8 dB
Frequency (Hz)
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Channel ID
Modulation
Symbol Rate (Msym/sec)
Interleave Depth
Power Level (dBmV)
RxMER (dB)
Upstream   US-1 US-2 US-3 US-4 2.0 2.0 N/A N/A 95 94 N/A N/A 24400000 Hz 31000000 Hz N/A N/A Success Success N/A N/A QAM64 QAM64 N/A N/A 5120000 5120000 N/A N/A 128 128 N/A N/A 45.0 dBmV 44.8 dBmV N/A N/A 0 0 N/A N/A 0 0 N/A N/A 0 0 N/A N/A 0 0 N/A N/A
Channel Type
Channel ID
Frequency (Hz)
Ranging Status
Modulation
Symbol Rate (Sym/sec)
Mini-Slot Size
Power Level (dBmV)
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
Any help greatly appreciated.
mark_tw
Message 3 of 8
Sorry the copy and paste of the table didn't work . screen shots below (took ages to upload small file! :-( ) Edit -  speedtest = ping 14ms, download - 45mbps (i have a 70 mbps package) and upload of 0.08mbps.
FireShot Capture 17 - Super Hub I GUI - http___192.168.0.1_VmRouterStatus_upstream.asp.pngFireShot Capture 118 - Super Hub I GUI - http___192.168.0.1_VmRouterStatus_downstream.asp.png
  • 5
Tim_TW1
Message 4 of 8
Same issue here. Just started today - normally very good service in area 03.
mark_tw
Message 5 of 8
I'm in TW1 too... 3rd day of poor broadband upload speeds
jwinterbourne
Message 6 of 8
I am also in Twickenham (TW2), third day, same problem...
  • 10
Maroda90
Message 7 of 8
So glad I read this! TW2 here, and none existant upload speeds since around Sunday lunch time.
There must be a problem in the area. Please say Virgin are looking into this?????
  • 8.29K
  • 355
  • 583
Message 8 of 8
Hi jwinterbourne,
Welcome to the Community!
Really sorry to hear you're having trouble with your Upload.
I've located your account and I can see an issue with the network in your area ref.(F005189566). Our technicians are working to get this resolved as soon as possible and have set a review for later on today.
All the best! Smiley Very Happy
Josh
