DR68
Wifi speed
hi
what speed should I be getting on wifi I have vivid 200 broad band, I have done speed tests but only ever get 15-17 Mbps
  • 5.66K
  • 291
  • 1.25K
Re: Wifi speed
No one can say.
Depends on what device/what band you are connecting too/distance/walls/how much wireless interference you have.
To reach 200Mbs you will need to be using a AC router, and an AC capable device, preferably being relatively close with no walls.
What speeds do you get wired?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
DR68
Re: Wifi speed
I don't know what speeds I get wired as I only have a iPad. I'm usually no more than 10 feet away from the router with no walls between .
  • 9.36K
  • 799
  • 1.96K
Re: Wifi speed
What model iPad?
Are you using the 2.4GHz or 5Ghz band?
