Joe1312
Message 1 of 8
Whats going on? - Upload Speed Terrible
I'm not sure if this is a problem in my area or what, for the last couple of months my upload speed has been 2-3 MBPS when i have 50-5 MBPS download?
I've read online and your upload speed is suppose to be 10% of your download, so i should at least be getting around 5.5 MBPS upload?
(I live in LFE, Leicestershire, UK)
Joe1312
Message 2 of 8
Re: Whats going on? - Upload Speed Terrible
50-55 MBPS download speed
  • 22.22K
  • 845
  • 3.23K
Message 3 of 8
3mbps is the correct upload for 50mbps as far as i know (its been awhile i might be behind on the data) the 105 upload was dropped years ago when 150mbps came out.
  • 1.46K
  • 87
  • 342
cje85
Knows their stuff
Message 4 of 8
3Mbps is the correct upload speed for the 50mb service.
The current download / upload speeds for each package are:
(Down / Up)
50Mb / 3Mb
70Mb / 5Mb
100Mb / 6Mb
150Mb / 10Mb
152Mb / 12Mb
200Mb / 12Mb
200Mb / 20Mb (Gamer package: this is the only one where upload is 10% of download)
  • 16
ravickas
Message 5 of 8
i got 70mb but my upload speed is only 1.7 and i dont know why is like that
  • 12.48K
  • 353
  • 1.45K
Message 6 of 8
Hi ravickas,
I have just checked your connection and your QOS is showing at 5mb for your upstream speeds, so it's odd your not seeing this from your side.
Would you do me a favour please and run a couple of speed tests via speedtest.net and post the results on here?.
Please do this via a pc or laptop that is hard wired to the Hub.
We'll then take a look and see what advice we can offer.
Thanks Smiley Happy
Jen
Joe1312
Message 7 of 8
Hi there, thank you for your help, here is my speedtest results, i ahve recently upgraded to the superhub 3.0 which may may a little difference but either way ive been using ethernet with every router, but it doesnt seem to change, heres the results http://beta.speedtest.net/result/6100988774
  • 111
  • 8
  • 39
voicon
Up to speed
Message 8 of 8
Your speed is correct, on 50mb you only get 3mb upload, that speed test is perfect.
