jan9912
What Speed do I need
What Speed do I need to run netflix and kodi, (not at the same time) please my sister needs to cut her bills down.
Jan
  • 2.96K
  • 378
  • 939
Re: What Speed do I need
Hi Jan
Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
The above was taken from the Netflix help pages: https://help.netflix.com/en/node/306
______________________
Scott
