  • 11
coldfusion0
Message 1 of 5
Vivid gamer upload speed drop
so I am vivid gamer package and my upload speed has dropped last time I spoke broadband support they said reboot the the hub .3.0 weekly basis and that had been working until tonight
rebooted via network web page and that didn't solve it so turned off for 5 minutes that didn't solve it either
6794034912
  • 5.65K
  • 290
  • 1.25K
Message 2 of 5
Re: Vivid gamer upload speed drop
18.5Mbs. Working fine. It is 'up to' and if the area usage is making it dip a tiny unnoticeable bit i'm not sure what you want.
Or is it dropping lower?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 90
  • 14
chriscdotcodot
Dialled in
Message 3 of 5
I often get slower than noted speeds when I run a speedtest. The upload part of the site seems bad at giving accurate readings but when I actually look at traffic on my network and on the router I see that it is actually more consistently hitting 20ish than lower or higher results. I spent a week of having speed test results showing an upload speed in excess of 30Mbps which is wrong but my router was reporting correctly.
In short, your numbers look okay.
  • 11
coldfusion0
Message 4 of 5
it's been all over the place as low 12 just slightly annoyed as this package was advertisted for twitch streamers and you can't stream on 12Mbps
  • 5.65K
  • 290
  • 1.25K
Message 5 of 5
You can stream on 12Mbs, and with a decent quality too (heck I’ve streamed when I was on lower packages too). Maybe you should tweak your settings a bit as you are probably going for too high a quality that isn’t even noticeable. Got to bear in mind what your viewers can watch in too.
