  • 14
JBMedia
Message 1 of 16
Vivid Gamer has more than halved my speed. Technical help needed.
Hi All,
I have full CAT 6, 1Gbs FULL Duplex set and am getting atrocious speeds. I have previously been getting well over 200Mbs.
Downstream -
Acquired Downstream Channel(Hz)
323000000
Locked
Upstream -
Ranged Upstream Channel(Hz)
24400000
Locked
Network Log -
Date And TimeError NumberEvent Description2017-01-25 10:46:14.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 10:46:53.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:35:08.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:36:21.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:36:33.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:36:33.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:36:33.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:36:38.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:37:06.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:38:20.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:38:24.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-25 14:38:46.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-27 21:38:32.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-29 22:47:53.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-30 21:48:37.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-30 23:40:05.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-31 03:13:19.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-01-31 03:13:19.0068010600DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-03 13:16:54.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-04 18:50:41.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Note - ~The Superhub is in Modem mode - It is plugged into an Asus RT-N66U.
Please help me, and if you require anymore information please let me know.
Josh
  • 8.62K
  • 552
  • 2.38K
Message 2 of 16
Re: Vivid Gamer has more than halved my speed. Technical help needed.
Reboot hub and re-post your power levels. According to that you only have one downstream and upstream locked...
Did you get a new HUB as part of the upgrade?
  • 14
JBMedia
Message 3 of 16
Rebooted. No new hub.
Screenshot...
EDIT -
Full down -
Full Up -
  • 14
JBMedia
Message 4 of 16
Disappointed Face on Microsoft Windows 10 Anniversary Update
  • 10.02K
  • 332
  • 877
Hero
Message 5 of 16
Run this speed at mid night
http://www.thinkbroadband.com/speedtest.html
what NIC do you have?
  • 14
JBMedia
Message 6 of 16
Intel(R) Ethernet Connection I217-V
EEE IS DISABLED
  • 14
JBMedia
Message 7 of 16
Bump
  • 111
  • 8
  • 39
voicon
Up to speed
Message 8 of 16
It takes week to get an answer from Virgin themselves.
Apparently if you post again you go to the back of the queue, not sure if this is true and if it is it's ridiculous!
  • 5.65K
  • 290
  • 1.25K
Message 9 of 16
It is true.
It means everyone should get a reply rather than just whoever is at the top of the forum from posting the most.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 14
JBMedia
Message 10 of 16
Virgin are just becoming more and more of a joke...
