  • 52
denizen
Vivid Gamer 200 less than half speed
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
129875000010.540.3256 qam17
23227500001140.3256 qam20
33147500001140.3256 qam19
429075000010.140.3256 qam16
52827500001040.3256 qam15
62747500001040.3256 qam14
726675000010.140.3256 qam13
830675000010.540.3256 qam18
925875000010.440.9256 qam12
1025075000010.340.3256 qam11
112427500001040.3256 qam10
122347500001040.3256 qam9
132267500001040.3256 qam8
1421875000010.440.3256 qam7
1521075000010.340.3256 qam6
1620275000010.340.3256 qam5
1719475000010.540.3256 qam4
1818675000010.540.3256 qam3
1917875000010.440.3256 qam2
2017075000010.440.3256 qam1
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
2545800000ATDMA37.316 qam64000005120
2635800000ATDMA37.316 qam64000005120
Network Log Date And Time Error Number Event Description
2017-01-28 11:39:42.0069020600Improper Configuration File CVC Format
2017-01-28 11:39:42.0069020700Configuration File CVC Validation Failure
1970-01-01 00:01:26.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:26.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:25.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:25.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:23.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:23.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-28 18:53:53.0069010200SW Download INIT - Via Config file
2017-01-28 18:58:10.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-28 18:59:04.0069011000Disruption during SW download - RF removed
2017-01-28 18:59:07.0069010200SW Download INIT - Via Config file
2017-01-28 19:11:23.0069011200SW download Successful - Via Config file
2017-01-29 01:57:52.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Helpful Answers
  • 5.66K
  • 291
  • 1.25K
Re: Vivid Gamer 200 less than half speed
That's indicating something is limiting your connection to a 10/100 connection (which caps out at 90Mbs), and not the full gigabit 10/100/1000 connection needed for speeds above ~90Mbs
The common culprits are:
The Ethernet cable (need to be cat5e or better, undamaged)
The Ethernet ports on your device you are connecting with only being FE and not gigabit.
The network card of your device being FE
Software (killer Ethernet controller, set it to full duplex)
Can you go to the device manager on your computer and look at what it says in the networking section for what it says you have.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 5.66K
  • 291
  • 1.25K
And what speeds are you getting?
Wired or wireless?
  • 52
denizen
Wired, 80-90 down, 20 up.
  • 5.66K
  • 291
  • 1.25K
  • 52
denizen
Well this is embarrassing - I work in IT, read your post with the usual "I work in IT, I know what I'm doing" mentality, but then remembered the cat5e cable I am using has a broken plug.
Just pushed it further into the back of my router (sh3 in modem mode), and now have 220mbit down.
Cable must have been running at 100Mbit when not fully in port. Thank you - close this case.
  • 5.66K
  • 291
  • 1.25K
No worries, sometimes it takes a jolt to the memory!
