mssk
Message 1 of 7
Vivid 200 - speed is les then 10mb/s
I have Vivid 200 fibre, SuperHub 3.0 Wifi box is in the living room. And I'm always sitting in the kitchen. Between me and wifi box is only one wall(one wall Karl)- but speed is so slow... i have tried to restart the box,nothing helpd.
http://www.speedtest.net/my-result/6077149666
To wifi box connected only 3 phones and this Laptop. Wifi status is showing that everything is OK. if it`s okay, where is the speed? Smiley Sad
Upstream
42    39400000  ATDMA  49  16 qam  6400000  5120
44   25800000  ATDMA  49   16 qam  6400000  5120
Downstream
1 299000000 -0.7 38.9 256 qam 13
2 323000000 -0.9 40.3 256 qam 16
3 315000000 0.7 40.3 256 qam 15
4 307000000 0.7 40.3 256 qam 14
5 291000000 0.7 40.3 256 qam 12
6 283000000 0.7 40.3 256 qam 11
7 275000000 0.7 40.3 256 qam 10
8 267000000 0.7 40.3 256 qam 9
9 259000000 -0.5 40.9 256 qam 8
10 251000000 0.7 40.9 256 qam 7
11  243000000 0.7 40.3 256 qam 6
12 235000000 -0.5 40.3 256 qam 5
13 227000000 -0.5 40.3 256 qam 4
14 219000000 -0.4 40.3 256 qam 3
15 211000000  0   40.3 256 qam 2
16 203000000 0.2 40.9 256 qam 1
 Any advice?
Helpful Answers
mssk
Message 4 of 7
Re: Vivid 200 - speed is les then 10mb/s
laptop model Dell 5000 series with i7
mssk
Message 6 of 7
The problem is resolved.I called customer services. and it was a Virgin problem with a connection in my area.
All Replies
  • 1.27K
  • 94
  • 235
stevedh2
Knows their stuff
Message 2 of 7
Could you do a test with a wired connection please so that you can identify if the problem is the wifi or your internet connection.
  • 9.34K
  • 797
  • 1.96K
Message 3 of 7
You will need to test the actual internet connection speed wired directly to the hub with a Cat 5e cable or better with a device equiped with a gigabit ethernet network card. Wireless is just too unreliable to test the actual internet speed accurately as it is affected my many external factors like Range, Client hardware, Interference and the  Topography of your home. For example, a stud partition wall will absorb about half of the wireless signal's strength.
If you are getting headline wired speeds during the day and during the evening peak, then it loos like a wireless problem as opposed to a problem with your internet connection. Once the problem is confirmed as a wireless problem then we can investigate further.
What laptop (make / model) are you testing with?
mssk
Message 4 of 7
  • 9.34K
  • 797
  • 1.96K
Message 5 of 7
And your speed whilst wired directly to the hub?
The laptop should have a gigabit ethernet adapter from what specs I have seen, so should be capable of 200Mbps
What wireless adapter does the laptop have? According to the Dell website the wireless adapter is an option ranging from single stream wireless N adapters to the new wireless AD adapter. I suspect it is a wireless AC adapter from the specs of the "off the shelf" laptops I have seen. If confirmed that is an AC adapter then 200Mbps should be achievable close to the router with a clear line of sight.
mssk
Message 6 of 7
Rave9186
Just joined
Message 7 of 7
Straight from the outsourced handbook >.<
