efpk1959
Vivid 200 speed eratic
Hello,
I have been on Virgin Media broadband vivid 200 for just two days, but the speed is varying dramatically.  My download speeds have been as high as 218 mb and as low as 2 mb.  I have reset hub twice and speeds went up immediately to where they should be. This morning when I checked speed it was 21 mb, this time I didn't reset hub and it was 176 mb 15 mins later, then dropped back to 54mb.
I am using Speedtest.net to check speed.
  • 8.29K
  • 355
  • 583
Re: Vivid 200 speed eratic
Hi efpk1959,
Welcome to the Community!
Really sorry to hear you're experiencing issues with your connection.
I've located your account and I can see an issue with the network in your area causing intermittent services - Ref.(F005051934). Our technicians are working to get this resolved as soon as possible and have set a review date of 10th February.
I'll check back with you on the review date to make sure everything is OK.
Speak soon Smiley Very Happy
Josh
efpk1959
  • 8.29K
  • 355
  • 583
Hi efpk1959,
I've checked the network and the SNR outage has been closed.
There is still an issue at peak times F004725904 but it won't have nearly the same impact as the SNR outage.
How is your connection now?
Josh
efpk1959
Hi Josh,
My connection has been a lot better over the last couple of days. The highest speed 221 Mbps and lowest 148 Mbps.
Thank You.
  • 8.29K
  • 355
  • 583
Hi efpk1959,
That's awesome, good to see those speeds back where they should be!
Keep an eye on it and give me a shout if you get any more trouble.
All the best! Smiley Very Happy
Josh
