Damo31
Message 1 of 7
Vivid 200 Gamer slow upload speed
Having just upgraded to the vivid 200 gamer package to enable me to stream games to twitch at a higher bitrate, I have noticed that the upload speed is only about half what i'm paying for, about the same as my vivid 152 package, any ideas what the problem could be?
http://www.speedtest.net/my-result/6117275418
Damo31
Message 2 of 7
Re: Vivid 200 Gamer slow upload speed
I forgot to mention that I live in a semi rural area and the download speed is better than I'm paying for so I doubt its high network traffic
  • 9.34K
  • 797
  • 1.96K
Message 3 of 7
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
Damo31
Message 4 of 7
1 298750000 4.8 37.3 256 qam 13
2 322750000 4.6 37.3 256 qam 16
3 314750000 4.8 37.3 256 qam 15
4 306750000 4.6 37.6 256 qam 14
5 290750000 4.8 37.3 256 qam 12
6 282750000 4.8 37.6 256 qam 11
7 274750000 4.8 37.6 256 qam 10
8 266750000 4.6 37.3 256 qam 9
9 258750000 4.6 37.6 256 qam 8
10 250750000 4.9 37.6 256 qam 7
11 242750000 4.9 37.6 256 qam 6
12 234750000 5 37.6 256 qam 5
13 226750000 5.3 37.3 256 qam 4
14 218750000 5.5 37.6 256 qam 3
15 210750000 5.5 37.3 256 qam 2
16 202750000 5.8 37.6 256 qam 1
15 60300000 ATDMA 35.5 16 qam 6400000 5120
13 45800000 ATDMA 35.5 16 qam 6400000 5120
1970-01-01 00:01:33.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:34.00 84020300 MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:27.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:28.00 84020300 MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-09 18:00:50.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-09 18:01:33.00 69010200 SW Download INIT - Via Config file
2017-03-09 18:06:00.00 69010900 Disruption during SW download - Power Failure
2017-03-09 18:06:04.00 69010200 SW Download INIT - Via Config file
2017-03-09 18:11:45.00 69010900 Disruption during SW download - Power Failure
2017-03-09 18:11:59.00 69010200 SW Download INIT - Via Config file
2017-03-09 18:24:59.00 69011200 SW download Successful - Via Config file
Hope that helps.
Damo31
Message 5 of 7
Got even worse tonight, so much so that I started dropping frames on my stream, not at all impressed!!
http://www.speedtest.net/my-result/6122656551
  • 10.82K
  • 308
  • 632
Message 6 of 7
Hi there Damo31,
My apologies you are having an issue with the upload speeds.
Looking at the network there is high traffic on the upstream channels which I have raised to our networks department for further investigation. Once I have more information I will let you know.
Will speak to you soon
Sam
  • 10.82K
  • 308
  • 632
Message 7 of 7
Hi Damo31,
Just wanted to let you know more information in regards to the fault I raised.
The reference number is F005150627 and has a review date of 3rd May.
If there is anything else you would like me to check, by all means let me know.
Sam
