Ozzyj
Message 1 of 5
Virgin speed
I have just signed up to vivid 100 but can only get 20mps. Tried to call help line and just got cut off half way through trying to explain. Any ideas? Area code is 22.
at this rate I might hav well stayed with sky Smiley Sad
JHRUS
Message 2 of 5
Re: Virgin speed
We also experiencing very slow and interrupted service, area 21 - I have re-set the router 2x to factory setting and that helped a little bit.
We are now waiting for a brand new router and hopefully that sorts the problem out, otherwise we will leave Virgin. What is the point advertising super speed broadband if customers actually get them.
  • 5.34K
  • 270
  • 1.17K
Message 3 of 5
Re: Virgin speed
Are you testing wired or wirelessly?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
Ozzyj
Message 4 of 5
Re: Virgin speed
Wirelessly. Even so I wouldn't expect such a slow speed relative to advertised
  • 5.34K
  • 270
  • 1.17K
Message 5 of 5
Re: Virgin speed
Well if you want to see if it's just a issue on your line or if it's just the limitations of wireless being the limitations of wireless, you will want/need to do wired tests to see what speeds they come back with.
No ISP guarantees wireless speeds as there are too many factors outside of their control.
