  • 11
bogdanpopa
Message 1 of 14
Very low speed Area 22
Hi all.
It seems that the speed problem is spreading. Since yesterday I've got speeds of 2-3 Mbps....and not 50Mb. It is ridiculously low as even dial up can do better.
Frustration comes from the fact that we are paying for better broadband speeds before they were implemented, increases of prices, have been promised better speed when advirtised on phone etc.
And at the end of the day you don't get half of the speed you're paying for.
We are not using internet 24h a day, only  a few hours in the evening after work. We should have a decent speed at least for those hours.
I'll quoate the data from router below:
[quote]
First TimeLast TimePriorityError NumberDescription
10/03/2016 05:27:27 GMT10/03/2016 05:27:27 GMTCritical (3)82000200No Ranging Response received - T3 time-out
[/quote]
[quote]
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)266750000274750000282750000290750000298750000306750000314750000322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID910111213141516
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)0.850.971.070.920.910.660.460.23
RxMER (dB)35.2535.4235.6035.6035.9735.7835.4249.40
Pre RS Errors
 125009421908391828796904699440
Post RS Errors
 81188059797279107935789278930
 [/quote]
[quote]
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID92N/AN/A90
Frequency (Hz)25800000N/AN/A39400000
Ranging StatusSuccessN/AN/ASuccess
Modulation32QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)46.50N/AN/A47.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts35000
T4 Timeouts0000
 [/quote]
Please have a look on what's happening and keep us updated.
Tags (1)
Helpful Answers
  • 11
bogdanpopa
Message 3 of 14
Re: Very low speed Area 22
Hi.
Starting yesterday, at every 20 minutes or so, the router restart itself. Is it because of Bonfire (problems started in the same with the fireworks), works on the network or is the router?
Bogdan
All Replies
  • 10.82K
  • 308
  • 631
Message 2 of 14
Hi bogdanpopa
Welcome to the community and thanks for posting your Super Hub information, this does help us further.
Many apologies that you're experiencing issues with your broadband connection.
From checking your connection, there is a high peak time traffic fault in your area which is causing the slow speeds your currently experiencing. Our networks team are investigating the problem and are improving bandwidth and performance to help with this issue. The reference number is F004039607 and with a review date of 30th March.
In regards to the time-outs that you can see it does appear to have the same time-stamp. As the Super Hub has been online for over 100 days, you can reset these timers and re-boot the router.
I will check this fault nearer the date, once there is more information, I'll be back in touch.
Sam
  • 11
bogdanpopa
Message 3 of 14
Hi.
Bogdan
  • 11
bogdanpopa
Message 4 of 14
I've solved the problem temporarily. It seems that the Super Hub is at fault. I've setted it as Modem and I'm using my Netgear router in connection. Internet works fine and it doesn't reset every 20mins.
  • 27
  • 7
Kizza-1974
Message 5 of 14
What super hub have you got out of interest mate?
  • 11
bogdanpopa
Message 6 of 14
Yeah, only temporary. It restarted again and entered router mode. So I would probably need someone to take a look at it.
  • 11
bogdanpopa
Message 7 of 14
It is Superhub 2ac.
  • 11
bogdanpopa
Message 8 of 14
Network Log First Time Last Time Priority Error Number Description
09/11/2016 17:16:27 GMT 09/11/2016 17:16:27 GMT Warning (5) 66050310 Auth Success - Web login successful.
09/11/2016 16:48:04 GMT 09/11/2016 16:48:04 GMT Error (4) 68010302 DHCP WAN IP - 9....
09/11/2016 16:47:14 GMT 09/11/2016 16:47:14 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
09/11/2016 16:42:28 GMT 09/11/2016 16:42:28 GMT Error (4) 68010302 DHCP WAN IP - 9....
09/11/2016 16:41:37 GMT 09/11/2016 16:41:37 GMT Error (4) 68000407 TOD established
09/11/2016 16:40:11 GMT 09/11/2016 16:40:11 GMT Error (4) 68000407 TOD established
09/11/2016 16:24:02 GMT 09/11/2016 16:24:02 GMT Warning (5) 66050310 Auth Success - Web login successful.
09/11/2016 16:09:42 GMT 09/11/2016 16:09:42 GMT Warning (5) 66050310 Auth Success - Web login successful.
09/11/2016 16:00:30 GMT 09/11/2016 16:00:30 GMT Error (4) 68010302 DHCP WAN IP - 9....
09/11/2016 15:59:38 GMT 09/11/2016 15:59:38 GMT Error (4) 68000407 TOD established
09/11/2016 15:29:36 GMT 09/11/2016 15:29:36 GMT Warning (5) 66050310 Auth Success - Web login successful.
09/11/2016 15:26:12 GMT 09/11/2016 15:26:12 GMT Error (4) 68010302 DHCP WAN IP - 9....
09/11/2016 15:25:20 GMT 09/11/2016 15:25:20 GMT Error (4) 68000407 TOD established
08/11/2016 21:56:20 GMT 08/11/2016 21:56:20 GMT Error (4) 68010302 DHCP WAN IP - 9.....
08/11/2016 21:55:27 GMT 08/11/2016 21:55:27 GMT Error (4) 68000407 TOD established
  • 11
bogdanpopa
Message 9 of 14
Frequency (Hz) 170750000 178750000 186750000 194750000 202750000 210750000 218750000 226750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 1 2 3 4 5 6 7 8
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 4.32 3.89 3.94 4.40 4.40 4.18 4.09 3.99
RxMER (dB) 37.64 37.36 37.09 37.64 37.94 37.94 37.94 37.36
Pre RS Errors
717 733 345 394 314 957 300 305
Post RS Errors
310 306 280 295 295 954 292 300
  • 11
bogdanpopa
Message 10 of 14
Channel Type 2.0 N/A N/A 2.0
Channel ID 74 N/A N/A 76
Frequency (Hz) 39400000 N/A N/A 25800000
Ranging Status Success Other Other Success
Modulation 64QAM N/A N/A 64QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 45.00 N/A N/A 43.50
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
