  • 18
jdtuning
Message 1 of 22
Very Low Speed
After complaining to Virgin Media about my terrible download speed (around 40Mbs), I was told I needed to upgrade to the SuperHub 3.0 and pay £14.99 delivery charge.
I've waited 4 days for the SuperHub 3.0 to arrive.
In the mean time, I upgraded my home network and PC data transfer speed from 600Mbps to 1000Mbps.
So...
I'm paying for up to 200Mbps Virgin Media Service.
The Virgin Media SuperHub 3.0 is installed and set up.
I'm using:
TP-Link Gigabit PCI Express Network Adapter (TG-3468),
NETGEAR PL1000 - 1 Gigabit Ethernet Port Adapter,
Belkin Cat6 Snagless UTP Patch Cable's.
As you can clearly see from my screenshot....
Today's Speed TestsToday's Speed Tests
NO REASONABLE IMPROVEMENT IN SPEED.
These tests were done through wired connection, with only one device connected.
I have a fresh install of Windows 10. PC is only 3 weeks old.
Info from router:
Status
Acquired Downstream Channel(Hz)
299000000
Ranged Upstream Channel(Hz)
31000000
Downstream
12990000002.938.9256 qam69
2323000000338.9256 qam72
33150000002.738.9256 qam71
43070000002.738.9256 qam70
52910000003.238.6256 qam68
62830000003.740.3256 qam67
72750000003.438.9256 qam66
82670000003.238.9256 qam65
92590000003.238.9256 qam64
102510000003.438.9256 qam63
112430000003.738.9256 qam62
122350000004.138.9256 qam61
Upstream
34 31000000ATDMA35.364 qam64000005120
35 24400000ATDMA35.364 qam64000005120
Operational Configuration General Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
V0dea97109ea7aa00.cm
SFID41308
Max Traffic Rate230000000
Primary Upstream Service Flow
SFID41311
Max Traffic Rate12700000
1970-01-01 00:01:28.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:28.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:02:46.0068000100DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:04:10.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:04:10.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:05:28.0068000100DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:07:54.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:08:58.0068000100DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:27.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:27.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-03-23 15:45:59.0069010200SW Download INIT - Via Config file
2017-03-23 15:49:06.0069010900Disruption during SW download - Power Failure
2017-03-23 15:49:10.0069010200SW Download INIT - Via Config file
2017-03-23 15:57:51.0069011200SW download Successful - Via Config file
Many Thanks
JD
  • 8.61K
  • 552
  • 2.38K
Message 2 of 22
Re: Very Low Speed
Your upstream speeds are consistent- but your downstream is all over the place.
Power levels look fine...
I notice form your speed tests you are using different servers - most of which are outside VM's network. Try a speed-test at
speedtest.net
and chuck the screen-cap up.
  • 18
jdtuning
Message 3 of 22
Re: Very Low Speed
I was trying different location to find the best speed.
Here's the test I just done.
  • 8.61K
  • 552
  • 2.38K
Message 4 of 22
Re: Very Low Speed
So Im assuming you are using a wired connection- does it vary at different times of day?
Next-
So we can help us to help you, can you
Go to your Superhub Log in screen
Do NOT log in.
Little button top right.....
Can you post Upstream, Downstream and Network logs.
Screen caps are nice, C&P will do- Don't stress about formatting if you C&P. Someone will get a look and see if there's anything obvious amiss.
  • 18
jdtuning
Message 5 of 22
Re: Very Low Speed
2017-03-23 (1).png2017-03-23 (2).png2017-03-23 (3).png2017-03-23 (4).png[MOD EDIT: Inappropriate images removed (Contains Mac address and IP address), please review the Forum Guidelines]
  • 8.61K
  • 552
  • 2.38K
Message 6 of 22
Re: Very Low Speed
Everything looks fine from a power level point of view...but the network log looks ropey.
Set up a BQM
HERE
Run it for say 24 hrs, and post the result.
  • 18
jdtuning
Message 7 of 22
Re: Very Low Speed
Yes, as OP, Wired connection 1000Mbs, no other devices connected.
  • 18
jdtuning
Message 8 of 22
Re: Very Low Speed
I've been testing it for 3 weeks now.
Best Speed was 90Mbs
Worst was 8Mbs.
I was testing at varying times of the day, it's always slow.
  • 8.61K
  • 552
  • 2.38K
Message 9 of 22
Re: Very Low Speed
Set up the BQM.
It could be your WAN connection is dropping out, which the BQM will show us. It will also show us how latency varies throughout the day.
  • 18
jdtuning
Message 10 of 22
Re: Very Low Speed
As OP, I'm using a brand new Super hub 3.0, delivered and installed today.
I was also having the same issue before, with the Super hub 2...
All the tests I done previous are almost Identical to these ones using the Super hub 3.0...
Everything is brand new, down to the CAT6 cables.
I've started the BQM.
Will post back more info.
